grimbeaver Posted November 12, 2009 Author Share Posted November 12, 2009 Yup gone now!! Link to comment Share on other sites More sharing options...
TPLGT Posted January 22, 2010 Share Posted January 22, 2010 Get the greaseable sway bar bushes from Energy Suspension. No more clunk. http://www.energysuspension.com/media2/GreSwayBB.jpg http://www.energysuspension.com/pages/swaybbct.html I have had some clunking issues on the passenger rear since May 09. I am running Cobb Sways...swapped ELs...to Ralliteks and didnt help. Had the tech look at it and tighten everything down (man those Els are hard to snug up!)....on Bosco's reccomendation, I ordered a set of these^^^ thanks for the pic, Phil...going on next week. I hope it finally fixes the clunk for good. Rehab is for quitters. Link to comment Share on other sites More sharing options...
samsam Posted January 22, 2010 Share Posted January 22, 2010 I have had some clunking issues on the passenger rear since May 09. I am running Cobb Sways...swapped ELs...to Ralliteks and didnt help. Had the tech look at it and tighten everything down (man those Els are hard to snug up!)....on Bosco's reccomendation, I ordered a set of these^^^ thanks for the pic, Phil...going on next week. I hope it finally fixes the clunk for good. TPLGT , please keep me update after the bushing swape. I have to deal with the same issue . Did you have 22mm sway bar ? if yes, what's the part number for the greasable bushing & Mount ? Link to comment Share on other sites More sharing options...
AWDxBOOST Posted January 22, 2010 Share Posted January 22, 2010 try tightening up the h frame bolts, that fixed it on mine Link to comment Share on other sites More sharing options...
TPLGT Posted January 23, 2010 Share Posted January 23, 2010 TPLGT , please keep me update after the bushing swape. I have to deal with the same issue . Did you have 22mm sway bar ? if yes, what's the part number for the greasable bushing & Mount ? Will do. The part number for the greaseable bushings is 9.5158. This is for a 22mm Cobb rear sway. Rehab is for quitters. Link to comment Share on other sites More sharing options...
TPLGT Posted January 23, 2010 Share Posted January 23, 2010 try tightening up the h frame bolts, that fixed it on mine The tech took the impact gun to everything he could find...no dice. BTW, what are the H frame bolts? Rehab is for quitters. Link to comment Share on other sites More sharing options...
TPLGT Posted January 27, 2010 Share Posted January 27, 2010 I still have a nasty csae of the clunks. I just picked up a set of energy suspension greaseable bushings. They seem to be very heavy/beefy...theyre going on, Thurs. Fingers crossed this solves the problem (lingering since May). Rehab is for quitters. Link to comment Share on other sites More sharing options...
Pricci09 Posted May 6, 2010 Share Posted May 6, 2010 did the bushings solve the problem? i just installed a fsb and am having bad clunking Link to comment Share on other sites More sharing options...
samsam Posted May 6, 2010 Share Posted May 6, 2010 I changed the LGA bushing to STI group N part,whiteline steering rack bushing,noise still around! End up apply motorcycle chain lube to the front sway bar bushing, noise gone . Link to comment Share on other sites More sharing options...
ebpda9 Posted May 7, 2010 Share Posted May 7, 2010 i have the same clunk coming from the passenger front. I kinda narrowed it down to a bad upper strut since i am running no front sway. Link to comment Share on other sites More sharing options...
Ryandigi Posted June 22, 2010 Share Posted June 22, 2010 No clunk with a 25mm FSB....went autocrossing a month later and now I have the dreaded low speed/slight turning clunk. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 22, 2010 Share Posted June 22, 2010 Have you replaced the end links on the sway bar, 9 out of 10 times that's the noise. Perrin end links fixed my clunking. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Ryandigi Posted June 24, 2010 Share Posted June 24, 2010 Have you replaced the end links on the sway bar, 9 out of 10 times that's the noise. Perrin end links fixed my clunking. Don't know if this was directed towards me or the OP, but yes I also have rallitek springs (been on for 2 years with no clunking) and rallitek HD front and rear sway bar endlinks. Link to comment Share on other sites More sharing options...
laramieskibum Posted June 27, 2010 Share Posted June 27, 2010 fixed the clunk in mine, finally....found the security beeper was broken loose below the air box. could only hear the clunk/rattle on a left hand turn....which is when the right side of the car moves the most vertically, sloshing the beeper around in that well below the air box. Link to comment Share on other sites More sharing options...
Ryandigi Posted July 29, 2010 Share Posted July 29, 2010 fixed the clunk on my FSB. Tightened the endlinks with the suspension loaded and also installed homemade lateral locks because I had the materials handy. I believe the clunk was due to the end links needing a bit of extra twist. Link to comment Share on other sites More sharing options...
Evols Posted August 10, 2014 Share Posted August 10, 2014 Wow, what a mess. Seems like every solution is different. This is an old thread so I'm wondering if there's a more definitive solution out there yet. Anyone else had success with this? Link to comment Share on other sites More sharing options...
MDW25gt Posted September 3, 2014 Share Posted September 3, 2014 Interesting. I will try top hats. Link to comment Share on other sites More sharing options...
Evols Posted September 6, 2014 Share Posted September 6, 2014 Mine ended up being driver side Sway end link. It looked to be completely intact but replacing it solved the problem. However, I still feel that at low speed 10mph and less, the front end is quite noisey over bumps. It doesn't sound like anything is loose or binding but it just seems loud and a bit harsh. Link to comment Share on other sites More sharing options...
Evols Posted September 6, 2014 Share Posted September 6, 2014 fixed the clunk on my FSB. Tightened the endlinks with the suspension loaded and also installed homemade lateral locks because I had the materials handy. I believe the clunk was due to the end links needing a bit of extra twist. What did your locks end up looking like? Any pictures by chance? Link to comment Share on other sites More sharing options...
don7 Posted September 18, 2014 Share Posted September 18, 2014 I have a clunk over speed bumps, and i think i have narrowed it down to either engine or tranny mounts. If i coast over speed bumps i get a clunk/click, HOWEVER if i slow down to almost nothing and lightly accelerate over... dead silent. I have not replaced them yet so i cant say for sure but its the best i can think of for now because my endlinks are good, and i have new swaybar bushings. Could also be LCA bushings too because they are shot. Give the speed bump thing a try though and see if it changes anything for you. Link to comment Share on other sites More sharing options...
Drogos Posted June 8, 2015 Share Posted June 8, 2015 another case for a clunk. I was thinking to start with 21mm stock replacement whiteline sway bar bushings. Will install these and we'll go from there: http://autoplicity.com/7579949-energy-suspension-195105r-sway-bar-bushing-set Link to comment Share on other sites More sharing options...
