icrackedcorn Posted June 25, 2008 Share Posted June 25, 2008 This is a compendium of EVERYTHING for all LGT/OB models form 1990-1999 :spin:im not responsible for anything:spin: I. Torque Specs --------------------Tune Ups --------------------Engine --------------------Heating/Cooling --------------------Fuel & Exhaust --------------------Transmission --------------------Clutch/Drive line --------------------Brakes --------------------Suspension & Steering II. Error Codes --------------------OBI --------------------OBII III. Capacities IV. Clearances V. Electrical VI. General Specs obedience to church and state is subjugation to the unjust authority of men Link to comment Share on other sites More sharing options...
icrackedcorn Posted June 25, 2008 Author Share Posted June 25, 2008 I. Torque Specs (ft-lbs unless noted) Tune Ups Trans drain plug -auto............18 -manual........30 Auto front dif drain plug........30 Engine oil drain plug.............30 Spark plugs.........................15 Wheel lugs..........................72 Engine Camshaft seal retainer/support (2.2L) N/a..................................120 to 144 in-lbs turbo................................72 to 84 in-lbs Camshaft Sprocket Bolts 2.2L................................47 to 54 2.5L................................55 to 61 Camshaft Pulley Bolt 2.2L................................70 to 80 2.5L................................90 to 100 Camshaft retainer (2.5L)...........................70 to 90 in-lbs Connecting rod nuts.................................32 to 34 Crankcase bolts short...............................17 to 20 long................................35 to 37 Crankcase service hole plugs plugs...............................46 to 56 cover screws....................48 to 60 in-lbs Engine to trans bolts................................34 to 40 Flywheel housing to engine........................25 to 30 Flywheel to crankshaft..............................51 to 55 Front exhaust to engine............................18 to 22 Intake manifold bolts................................168 to 192 in-lbs Oil pan bolts...........................................36 to 48 in-lbs Oil pressure sending unit...........................14 to 18 Oil Pump mounting bolts............................48 to 60 in-lbs Oil strainer mounting bolts.........................72 to 84 in-lbs Rocker arm assembly (2.2L).......................96 to 108 in-lbs Timing belt cover.....................................36 to 48 in-lbs Timing belt idler sprocket...........................26 to 32 Timing belt tensioner mounts 1997& earlier....................17 to 20 1998+1999......................26 to 32 Valve cover bolts.....................................36 to 48 in-lbs Cooling/Heating/AC Water pump to engine...............................84 to 120 in-lbs Trans oil line clamp-to-chassis....................72 to 120 in-lbs Fan shroud to radiator...............................48 to 72 in-lbs Fan to electric motor nut...........................24 to 48 in-lbs Thermostat housing bolts...........................48 to 60 in-lbs Radiator mounting bolts.............................72 to 120 in-lbs Condenser mounts....................................60 to 108 in-lbs Compressor mounts..................................18 to 24 AC lines to condenser...............................72 to 132 in-lbs AC lines to evaporator...............................14 to 20 Fuel and Exhaust Throttle Body mounting bolts....................15 to 18 Fuel Rail mount.......................................84 to 108 in-lbs Fuel Injector pipe-to-manifold....................13 to 15 Fuel injector holder mount.........................24 to 36 in-lbs Turbo-to-exhaust manifold........................18 to 24 cooling pipe to turbo................................15 to 17 turbo oil inlet pipe bolt to engine block.........120 to 156 in-lbs oil inlet pipe bolt to turbo..........................15 to 17 exhaust pipe to exhaust manifold bolts.........15 to 20 EGR Pipe.................................................23 to 26 Manual Transmission Back up light/neutral switch.......................16 to 19 Trans to axle fasteners Lower nuts.............34 to 39 Upper Right Bolt.......34 to 39 Automatic Transmission Shift cable adjustment nut.........................48 to 81 in-lbs Torque converter mount............................17 to 19 Trans to engine.......................................34 to 40 Clutch/Drive line Center Bearing Retaining Bolts....................35 to 41 Center Bearing Flange nut.........................180 to 220 Clutch Pressure plate bolts........................132 to 144 in-lbs Drive shaft to pinion flange nuts/bolts.........18 to 28 Driveaxle nuts (front and rear)...................123 to 151 Rear diff pinion flange nut.........................123 to 144 Brakes brake hose to caliper banjo bolt..................132 to 180 in-lbs caliper support bracket bolts -front..............16 to 23 -rear...............25 to 33 front caliper lockpin..................................25 to 33 master cylinder mounting nut......................96 to 156 in-lbs proportioning valve mounting bolts..............15 to 21 rear caliper lockpin...................................144 to 204 in-lbs wheel cylinder mounting nuts......................72 to 96 in-lbs Suspension & Steering ball-joint to control arm nut........................29 control arms front pivot...............................................61 to 83 rear pivot................................................130 to 144 rear bushings...........................................145 to 217 stabilizer bar bushing clamp bolts...................................16 to 21 stabilizer to link bolts/nuts..........................28 to 37 link to control arm bolts..............................16 to 22 steering knuckle to ball joint pinch bolt..........28 to 37 Strut/Coil Assembly damper rod to mount nut............................37 to 50 strut to steering knuckle.............................98 to 115 strut upper mounting nut...........................120 to 192 in-lbs Control Arms Control arm to cross member........................87 to 116 Control arm to rear knuckle..........................87 to 116 rear hub and bearing retaining nut (2WD)........123 to 151 Trailing Arms Trailing arm to body....................................72 to 94 trailing arm to rear knuckle...........................72 to 94 Power Steering pump pulley -1990 to 94.........31 to 46 -195 and up.........40 to 49 Tie-rod end to steering knuckle......................19 to 21 steering gear mounting bolts..........................35 to 52 steering shaft u-joint pinch bolt.....................15 to 19 steering wheel nut.......................................22 to 29 obedience to church and state is subjugation to the unjust authority of men Link to comment Share on other sites More sharing options...
icrackedcorn Posted June 25, 2008 Author Share Posted June 25, 2008 II. Error Codes OBI: reading OBI codes- the first digit of the code is the number of long flashes, the second is the number of short flashes 11: crank angle sensor 12: starter switch 13: cam angle sensor 14: fuel injector #1 15: fuel injector #2 16: fuel injector #3 17: fuel injector #4 21: coolant temp sensor 22: knock sensor 23: airflow sensor 24: air control valve 31: throttle position sensor 32: oxygen sensor 33: vehicle speed sensor 35: purge control solenoid valve 41: fuel mixture LEAN 42: idle switch 44: wastegate control solenoid 45: atmospheric sensor 49: airflow sensor 51: neutral switch 52: inhibitor switch OR parking switch OBII: P0100= MAF sensor or circuit malfunction P0101= MAF sensor range error P0102= MAF sensor circuit low input P0103= MAF sensor circuit high output P0105= Pressure sensor or circuit malfinction P0106= Pressure sensor range error P0107= Pressure sensor circuit low input P0108= Pressure sensor circuit high input P0115= Electric Coolant Temp (ECT) sensor or circuit malfunction P0116= ECT sensor circuit low input P0117= ECT sensor circuit high input P0120= Throttle position sensor (TPS) or circuit malfunction P0121= TPS range error P0122= TPS circuit low input P0123= TPS circuit high output P0125= Insufficient cooling temp for closed loop P0130= Upstream o2 sensor or circuit malfunction P0133= Upstream o2 sensor slow response P0135= Upstream o2 sensor heater circuit malfunction P0136= Downstream o2 sensor or circuit malfunction P0139= Downstream o2 sensor slow response P0141= Downstream o2 sensor heater circuit malfunction P0170= Fuel Trim malfunction (lean or rich) P0181= Fuel temp sensor range error P0182= Fuel temp sensor low input P0183= Fuel temp sensor high input P0201= Fuel injector 1 malfunction P0202= Fuel injector 2 malfunction P0203= Fuel injector 3 malfunction P0204= Fuel injector 4 malfunction P0261= Fuel injector 1 circuit low input P0262= Fuel injector 1 circuit high output P0264= Fuel injector 2 circuit low input P0265= Fuel injector 2 circuit high output P0267= Fuel injector 3 circuit low input P0268= Fuel injector 3 circuit high output P0270= Fuel injector 4 circuit low input P0271= Fuel injector 4 circuit high output P0301= Cylinder 1 misfire P0302= Cylinder 2 misfire P0303= Cylinder 3 misfire P0304= Cylinder 4 misfire P0325= Knock sensor circuit malfunction P0335= Crankshaft position sensor circuit malfunction P0336= Crankshaft position sensor circuit range error P0340= Crankshaft position sensor circuit malfunction P0341= Crankshaft position sensor circuit range error P0400= EGR flow malfunction P0403= EGR circuit malfunction P0420= Catalyst system efficiency below threshold P0440= EVAP system malfunction P0441= EVAP system incorrect purge flow P0443= EVAP system purge control valve or circuit malfunction P0446= EVAP vent control malfuntion P0451= EVAP fuel tank pressure sensor range error P0452= EVAP fuel tank pressure sensor low input P0453= EVAP fuel tank pressure sensor high output P0461= Fuel level sensor range error P0462= Fuel level sensor low input P0463= Fuel level sensor high input P0500= VSS or curcuit malfunction P0505= IAC system malfunction P0506= IAC system rpm low P0507= IAC system rpm high P0600= serial communtications link malfunction P0601= internal control module memory error P0703= Brake switch malfunction P0705= Transmission range sensor or circuit malfunction P0710= Transmission fluid temp sensor or circuit malfunction P0720= VSS circuit malfunction P0725= engine speed circuit malfunction P0731 thru P0734= incorrect gear ratio P0740 thru P0743= torque converter clutch system malfunction P0784 thru P0763= shift solenoid circuit malfunction obedience to church and state is subjugation to the unjust authority of men Link to comment Share on other sites More sharing options...
icrackedcorn Posted June 25, 2008 Author Share Posted June 25, 2008 III. Capacity Engine oil (w/ filter change) 2.2L 90-94......................4.8 qts 1995+.....................4.2 qts 2.5L........................4.7 qts Cooling system 2.2L 90-94.....................7.4 qts 1995+.....................6.1 qts 2.5L.......................6.3 qts Automatic Tranny standard refill after fluid & filter change (aprox.).......4 qts Total Capacity (refill after overhaul) 2.2L 90-93...............................................................8.8 qts 1994+..............................................................8.4 qts 2.5L.................................................................10 qts Manual Tranny 2.2L 90-94...............................................................4.2 qts 1995+...............................................................3.7 qts 2.5L.................................................................3.7 qts Differential front............................1.5 qts rear.............................0.8 qts obedience to church and state is subjugation to the unjust authority of men Link to comment Share on other sites More sharing options...
icrackedcorn Posted June 25, 2008 Author Share Posted June 25, 2008 coming soon obedience to church and state is subjugation to the unjust authority of men Link to comment Share on other sites More sharing options...
icrackedcorn Posted June 25, 2008 Author Share Posted June 25, 2008 V. Electrical ECU Pinout for EJ22 page 1 http://wac.addr.com/auto/obs/ecu1_sm.gif page 2 http://wac.addr.com/auto/obs/ecu2_sm.gif page 3 http://wac.addr.com/auto/obs/ecu3_sm.gif page 4 http://wac.addr.com/auto/obs/ecu4_sm.gif obedience to church and state is subjugation to the unjust authority of men Link to comment Share on other sites More sharing options...
icrackedcorn Posted July 14, 2008 Author Share Posted July 14, 2008 reserved obedience to church and state is subjugation to the unjust authority of men Link to comment Share on other sites More sharing options...
icrackedcorn Posted July 30, 2008 Author Share Posted July 30, 2008 update: torque specs and codes are complete, capacities might be all there.... obedience to church and state is subjugation to the unjust authority of men Link to comment Share on other sites More sharing options...
KuNomn Posted August 8, 2008 Share Posted August 8, 2008 Thank you Link to comment Share on other sites More sharing options...
sub20gt Posted August 11, 2008 Share Posted August 11, 2008 hey i crack.... thanks for the codes.... my slow flash was 6 and fast 6.... showing code 66.... what does that code mean.... every time that CEL comes on wid that code... my second turbo dont kick in until i switch off and switch on the car.... please help!!!!! Link to comment Share on other sites More sharing options...
icrackedcorn Posted August 12, 2008 Author Share Posted August 12, 2008 hey i crack.... thanks for the codes.... my slow flash was 6 and fast 6.... showing code 66.... what does that code mean.... every time that CEL comes on wid that code... my second turbo dont kick in until i switch off and switch on the car.... please help!!!!! i cant find anything specific in anything i have acquired... maybe you're just going to have to deal with one measly turbo like us north americans maybe check vacuum pressure sensor Ill be adding more obd 1 codes as i find them obedience to church and state is subjugation to the unjust authority of men Link to comment Share on other sites More sharing options...
sub20gt Posted August 12, 2008 Share Posted August 12, 2008 ive looked evry where for that one code but havent managed to get it... i even bought the haynes book for legecy overhaul.... but nufin there too!!! Link to comment Share on other sites More sharing options...
My Car Posted February 13, 2011 Share Posted February 13, 2011 Hey there. sorry if this is a huge thread bump but ive got a question. you said that: Camshaft retainer (2.5L)...........................70 to 90 in-lbs Connecting rod nuts.................................32 to 34 now im about to tighten the camshaft retainers on the head of my 94 legacy 2.2L non turbo motor. it says 70 - 90 in lbs for the 2.5L. WHAT ABOUT THE 2.2L?! im so confused that it only gives specs for the 2.5L in the book. and whats the connecting rod nuts? sorry if this is a FAQ. thanks in advance. Link to comment Share on other sites More sharing options...
Osei Posted February 14, 2011 Share Posted February 14, 2011 AFAIK the specs are the same. Just note the difference between INCH lbs and FOOT lbs. O. Link to comment Share on other sites More sharing options...
My Car Posted February 14, 2011 Share Posted February 14, 2011 ok im gonna take your word for it. ive also been calling around to auto stores and dealers and im not getting any straight answer at all. Link to comment Share on other sites More sharing options...
thisguys2130 Posted June 7, 2011 Share Posted June 7, 2011 Awesome info icrackedcorn! I had my legacy in firestones shop the other day so they could pinpoint which wheel bearing was bad for me and when I picked the car up I had to go back in because the check engine light was on which it was not when I dropped the car off. The code read (P0500= VSS or curcuit malfunction), this doesnt sound like it should of happened when all they had to do was put it on the lift put it in gear and listen to the bearings. What would make the car read that code? I am afraid they have done something to possibly sabotage my car or maybe played a sly trick to get me to come back because I told them I didnt want them to do the service since I can do it for half the price. Link to comment Share on other sites More sharing options...
