jospgut Posted June 9, 2008 Share Posted June 9, 2008 i need help with my 97 subaru legacy 2.5 gt, i just change the engine because, when i bought it the guy burn both head gaskets, well the engine that i put is from japan, and i live in oregon, i change the radiator and thermostat, and my car is overheating i found a lower temp thermostat do you think that the thermostat is the problem? Link to comment Share on other sites More sharing options...
blackfang Posted June 9, 2008 Share Posted June 9, 2008 You can try it, but we don't see them go bad that often. Many times it is the h/g's. [SIZE=1][URL="http://public.fotki.com/blackfang/"]Pics[/URL] [B]08 KawasakiZZR 600- exhaust and other mods 98 Camaro Z/28 HT- some mods......street/strip car 07 Legacy 2.5i- SPT exhaust...daily driver[/B][/SIZE] Link to comment Share on other sites More sharing options...
jospgut Posted June 9, 2008 Author Share Posted June 9, 2008 i just notice that the fans are not working! Link to comment Share on other sites More sharing options...
pheonix991 Posted June 10, 2008 Share Posted June 10, 2008 The fans won't turn on right when you start up the car. When the thermostat opens, the fans will turn on. A good way to test the fans is turn on the AC, if the fans turn on, your fans are fine. The fans also turn off at 45mph. Ummm... take it to the dealer, have them run a blown head gasket test? That is about as much help as I can do. Link to comment Share on other sites More sharing options...
jospgut Posted June 10, 2008 Author Share Posted June 10, 2008 thanks, anyways, i already tried to turn the ac and doesnt work now i have to figure it out if is the temp sensor or a fuse Link to comment Share on other sites More sharing options...
pheonix991 Posted June 11, 2008 Share Posted June 11, 2008 Go get a fuse tester from radio shack. Link to comment Share on other sites More sharing options...
jospgut Posted June 13, 2008 Author Share Posted June 13, 2008 finally i went to the subaru dealer and they said that problably is the fans relay or the temp sensor, but most sure is the relay and i dont know where it is, they said is under the diver side dash but i couldnt see it Link to comment Share on other sites More sharing options...
