05gtlimited300 Posted May 24, 2008 Share Posted May 24, 2008 I just debadged my car and everything turned out pretty good. I got all the glue off and the Legacy 2.5 GT is invisible but the Subaru is still there. Now i cleaned the crap out of it and waxed etc etc but its still there. The issue is (im not a paint expert) that it appear to be as if the clearcoat is gone because there is still paint underneath. Should i continue to was or polish it in hopes it blends or should i resort to a rubbing compound or worse new paint/clear coat?? Link to comment Share on other sites More sharing options...
TRSCobra Posted May 24, 2008 Share Posted May 24, 2008 Mine is the same way. I can only see the "subaru" or "legacy" in the right light at certain angles. I'm going to hand buff it with some cheap turtle wax polishing compound and see where that goes. Don't go with rubbing compound right off the bat as it's alot more aggressive than the polishing stuff. A little at a time, you know. YMMV Link to comment Share on other sites More sharing options...
Golf4283 Posted May 24, 2008 Share Posted May 24, 2008 i had the same problem then I used some pre-wax cleaner by Mothers. Buff it in and then wipe it off. works great! Link to comment Share on other sites More sharing options...
NSFW Posted May 24, 2008 Share Posted May 24, 2008 I debadged my 05 last year and it took a while to really get truly clean around the edges of where the letters were. More recently I learned the magic of the clay bar... try one. Then wash/clay the whole car and follow up with a sealant like NXT or the one from Wolfgang (I forgot the name). Link to comment Share on other sites More sharing options...
05gtlimited300 Posted May 24, 2008 Author Share Posted May 24, 2008 ill try the clay bar see if it helps, if not ill resort to heavier things like compounds Link to comment Share on other sites More sharing options...
jomamma Posted May 25, 2008 Share Posted May 25, 2008 use meguiars scratch x Link to comment Share on other sites More sharing options...
NSFW Posted May 25, 2008 Share Posted May 25, 2008 I've only used clay bar and NXT wax/sealant. I'll double check that the ghosting is truly 100% gone when I get the car in the sun today, but I don't think there is any need to use abrasives. Link to comment Share on other sites More sharing options...
jomamma Posted May 25, 2008 Share Posted May 25, 2008 the meguirs scratch x does not effect the clear coat. Link to comment Share on other sites More sharing options...
Hokiebird Posted May 27, 2008 Share Posted May 27, 2008 When I debadged I used goo gone then a clay bar. That should take care of it unless it's am issue with the paint fading or scratches around where the badge was. Link to comment Share on other sites More sharing options...
krzemienr Posted May 28, 2008 Share Posted May 28, 2008 when i debage cars in my detail shop once we get everything off, we use a clay bar and it get it perfect everytime, if that doesn't work, i'll use a 3m perfect-it II rubbing compound followed by a polish/glaze/wax... Link to comment Share on other sites More sharing options...
05gtlimited300 Posted May 28, 2008 Author Share Posted May 28, 2008 i used a bunch of goo gone originally and it go most of the adhesive off but it still says subaru so i still have to pick up the clay bar. im going to try the clay bar first with a polish and wax. if i dont like the results im going to step up to a compound. Link to comment Share on other sites More sharing options...
SneakyFast Posted May 28, 2008 Share Posted May 28, 2008 Claybar/polish/wax will get rid of it Link to comment Share on other sites More sharing options...
TRSCobra Posted May 29, 2008 Share Posted May 29, 2008 Claybar/polish/wax will get rid of it Worked like a charm on mine. No trace left at all. Link to comment Share on other sites More sharing options...
05gtlimited300 Posted May 29, 2008 Author Share Posted May 29, 2008 word Link to comment Share on other sites More sharing options...
NYtoVT Posted May 29, 2008 Share Posted May 29, 2008 at the dealer, we use 3M adhesive remover (or Goo-Gone) and a claybar. Link to comment Share on other sites More sharing options...
TRSCobra Posted May 29, 2008 Share Posted May 29, 2008 at the dealer, we use 3M adhesive remover (or Goo-Gone) and a claybar. On new cars, I presume? Link to comment Share on other sites More sharing options...
NYtoVT Posted May 29, 2008 Share Posted May 29, 2008 on all cars that need it. especially used/ trade-in cars that need the old dealer's sticker/ badge removed. sometime the new ones, coming off the trailer, that are wrapped in plastic. Link to comment Share on other sites More sharing options...
