enforcer Posted May 23, 2008 Share Posted May 23, 2008 Incredible write up! Thank you so much! I hate the idea of ripping apart my dash board so this write up is solid gold. One question though...I noticed that you didn't show us how to wire the gauge to the car. Does your gauge have a backlight? I would assume so. Link to comment Share on other sites More sharing options...
wpgspecb Posted May 24, 2008 Author Share Posted May 24, 2008 are you refering "wiring" as in the light up ? yeah im doing that tonight as i just got the wiring schematics for the 2006+ legacys, so now i know what is what. that part is very easy compared to what I have already posted look for it in less than 12 hrs. thanks for the positive feedback enforcer. I couldnt find any info on this topic so i went in blind and put up this for the next guys/gals. Jason Link to comment Share on other sites More sharing options...
wpgspecb Posted May 24, 2008 Author Share Posted May 24, 2008 make that 24 hrs Link to comment Share on other sites More sharing options...
wpgspecb Posted May 24, 2008 Author Share Posted May 24, 2008 update: Ive found a a-pillar dual gauge pod that fits our a-pillar almost perfectly, and by accident I have in my hands (so i know it fits) Auto meter http://autometer.com/img/linedot.gif 2002-2003 RSX: Dual Pod (Black) Product #: 20132 This fits very cleanly, of course it isnt perfect, but damnnnn close. i paid $39 canadian locally ($44 with tax) , they make a triple pod, but that gets very close to the SCA up near the head liner and this will have to be cut for sure. The dual pod can be had around $20us + shipping on ebay. I found a generic brand triple pod that fits the same car here, http://cgi.ebay.com/ebaymotors/_Car-Truck-Parts-Accessories__02-07-ACURA-RSX-GRAY-TRIPLE-PILLAR-GAUGE-POD-METER_W0QQitemZ270239565760QQadnZCarQ20Q26Q20TruckQ20PartsQ20Q26Q20AccessoriesQQadiZ2865QQcmdZViewItem?hash=item270239565760& this is only $20 us + shipping. This would need to be cut to fit, but nice to have 3 gauges on a legacy spec b, when you dont want gauges on your dash, and dont have the cubby because of NAV. here are my pics. http://jasonborowiec.com/specb/gauges/gauge%20pod/P5240001.JPG http://jasonborowiec.com/specb/gauges/gauge%20pod/P5240002.JPG http://jasonborowiec.com/specb/gauges/gauge%20pod/P5240003.JPG http://jasonborowiec.com/specb/gauges/gauge%20pod/P5240004.JPG http://jasonborowiec.com/specb/gauges/gauge%20pod/P5240005.JPG http://jasonborowiec.com/specb/gauges/gauge%20pod/P5240006.JPG http://jasonborowiec.com/specb/gauges/gauge%20pod/P5240007.JPG http://jasonborowiec.com/specb/gauges/gauge%20pod/P5240008.JPG http://jasonborowiec.com/specb/gauges/gauge%20pod/P5240009.JPG http://jasonborowiec.com/specb/gauges/gauge%20pod/P5240011.JPG http://jasonborowiec.com/specb/gauges/gauge%20pod/P5240012.JPG http://jasonborowiec.com/specb/gauges/gauge%20pod/P5240013.JPG http://jasonborowiec.com/specb/gauges/gauge%20pod/P5240014.JPG http://jasonborowiec.com/specb/gauges/gauge%20pod/P5240015.JPG http://jasonborowiec.com/specb/gauges/gauge%20pod/P5240016.JPG http://jasonborowiec.com/specb/gauges/gauge%20pod/P5240018.JPG Link to comment Share on other sites More sharing options...
wpgspecb Posted May 24, 2008 Author Share Posted May 24, 2008 i think the 3 pod would fit well, but i have the 2 pod in hand and am quite happy with it and know it works Link to comment Share on other sites More sharing options...
wpgspecb Posted May 24, 2008 Author Share Posted May 24, 2008 ok here is the wiring pictures. the gauge i used only has power and ground (white and black coming from the gauge), no dimming as its LED. I have extended the wires using black for negative and yellow for the power (i didnt have red or white) Ignition +12volts is a SOLID GREEN WIRE under the dash. this is what you want to tap so your gauges come on with ignition. unplug this brown plug, it sits just above the obd2 port http://jasonborowiec.com/specb/gauges/plugtowire.jpg the wire you want to tap is the SOLID GREEN wire. this wire is in the middle of the brown plug. the green wire you see at the bottom near my thumb nuckel actually has a grey stripe on the other side, this IS NOT the wire you want. the green wire is located just above my index finger in the cluster of wires. take the white tape off the wire bundle so its easier to untangle. next take an exacto knife and shave the plastic coating off the GREEN wire. you can see that other GREEN/GREY wire i was talking about now. DONT USE THAT ONE. Then attach the power wire (in my case the yellow wire) to this newly exposed wire. SOLDER after!!!!!!!! then tape or heat shrink. http://jasonborowiec.com/specb/gauges/wheretotap12voltignition.jpg thats it, now take the black wire and find a ground under a screw or bolt. i used one of the screws back up on the a-pillar where the air bag sits, just unscrew a screw about 4 turns and stick the wire under this. I used a LED light for my light so I did not fuse it. When I run my other 3-4 gauges I will fuse them all individually. hope this helps. If your gauge has another 3rd wire like orange or purple, then thats for the dimmer control, if you dont care about it dont hook it up, if you do want to dim the gauges, im not sure what wire is the dimmer. enjoy Link to comment Share on other sites More sharing options...
Gasaraki Posted May 25, 2008 Share Posted May 25, 2008 Wow, this thread is awesome. Thanks so much. Link to comment Share on other sites More sharing options...
wpgspecb Posted May 27, 2008 Author Share Posted May 27, 2008 i wish it was around when i did my gauges hehe Link to comment Share on other sites More sharing options...
fonts Posted May 27, 2008 Share Posted May 27, 2008 Coming along nice I see. Link to comment Share on other sites More sharing options...
Mark34 Posted May 27, 2008 Share Posted May 27, 2008 Subscribed.... interested in seeing how this comes out. Link to comment Share on other sites More sharing options...
Fox06LegacyGT Posted June 15, 2008 Share Posted June 15, 2008 any pics of the final fiberglassed piece? Link to comment Share on other sites More sharing options...
wpgspecb Posted June 15, 2008 Author Share Posted June 15, 2008 coming soon, the a-pillar pod i have is from a 2003 acura rsx, it almost lines up with no mod Link to comment Share on other sites More sharing options...
TSiWRX Posted June 20, 2008 Share Posted June 20, 2008 Great stuff! This is one to keep an eye on! <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
SIDrive Posted June 27, 2008 Share Posted June 27, 2008 subb'd Civilization has brought Evolution to a screeching halt 2007 Legacy GT auto 1989 Turbo Trans AM 1987 Buick Grand National 1983 DeLorean (Buick turbo transplant) Link to comment Share on other sites More sharing options...
Fox06LegacyGT Posted June 30, 2008 Share Posted June 30, 2008 not to steal your thunder wpgspecb, but for those that are interested: GI: A-Pillar Gauge Pod GB Link to comment Share on other sites More sharing options...
wpgspecb Posted July 1, 2008 Author Share Posted July 1, 2008 excellent i was hoping that someone would step up and make these for hte masses Link to comment Share on other sites More sharing options...
sschmelcke Posted November 18, 2008 Share Posted November 18, 2008 where did you get a universal circle mount??? Link to comment Share on other sites More sharing options...
Blazin2000 Posted January 21, 2009 Share Posted January 21, 2009 sorry to bump an old thread but was this ever finished?? pics? Link to comment Share on other sites More sharing options...
el5y Posted January 21, 2009 Share Posted January 21, 2009 thanks for the bump Blazin the spec B has a taupe upper half of the interior!? wtf? Link to comment Share on other sites More sharing options...
Blazin2000 Posted February 9, 2009 Share Posted February 9, 2009 anything yet?? I wanna see final pics cause I'm about to start fiberglassing mine in the next couple days Link to comment Share on other sites More sharing options...
tominator19 Posted April 2, 2018 Share Posted April 2, 2018 Btw, the part number for the A-pillar trim panel in the OP is slightly off. It's tough to figure out which circles are zeros vs. Os. Here's the correct number: TRIM PANEL-A PILLAR,UPPER LEFT: 94010AG09AOR Also, if you want the right side for some reason: TRIM PANEL-A PILLAR,UPPER RIGHT: 94010AG08AOR Link to comment Share on other sites More sharing options...
phish27134 Posted May 23, 2019 Share Posted May 23, 2019 (edited) I just recently acquired a 07 spec b, previous owner has a boost gauge on the top of the steering column, I'd like a A/F ratio and Oil pressure as well, so was thinking A pillar, but wasn't sure about air bag as I've not really looked at the FSM yet to verify, but assuming from previous threads its possible to have a triple gauge pod on the a-pillar, while not interfering with the air bag, i apologize if this sounds like a stupid question, I don't have much experience in the way of interior mods, especially since my older 97, 03 & 04 imprezas only had 2 airbags not 6. *EDIT* Correct me if I am wrong the side curtain airbag mostly sits alongside the ceiling pillars, I was under the assumption they were in the A-pillar & the sensor module is outside of the pillar as well? The only thing is the harness that runs up the A-pillar? Edited May 23, 2019 by phish27134 Correction/Specification Link to comment Share on other sites More sharing options...
