Guest adam07specB Posted May 18, 2008 Share Posted May 18, 2008 Hey everybody... i just got a perrin inlet pipe and intake and was wondering if i needed to tune the ECU or can i just put it on for now? I plan to do an exhaust and a tune however i need to finish buying a house so i wanted to just put the intake on.. I have a 2007 legacy spec.B any info would be most helpful. Link to comment Share on other sites More sharing options...
AKLGT Posted May 19, 2008 Share Posted May 19, 2008 run at your own risk. Do a search on intakes and you'll find a lot to learn. Wiggle wiggle wiggle wiggle wiggle yeah!!! Link to comment Share on other sites More sharing options...
SpawnGT Posted May 19, 2008 Share Posted May 19, 2008 the Intake may cause you to run lean or run rich, each intake is different no matter what the manufacterer says, at this point there is Cobb, AVO, K&N, WBR, and the CAI(i forgot the manufacterer), im assuming thats all of them. All of these intakes are entirely different then the OEM intake+filter+rest of the pieces that make the OEM intake. And since an aftermarket intake is by design dfferent then the OEM intake therefore you might have your engine start knocking, or pull timing, oreven cause a loss in boost. My factual experience with an aftermarket intake: AVO Intake, ran it for a month w/o tune. didnt notice anything "bad" happeneing, except he intake would have alot of fluttering throughout different RPMs,and different amounts of pressure on the accelelerator. I did see full boost, and i was running a TDC stage 2+ map for catless Turboback, Uppipe, and FMIC. Link to comment Share on other sites More sharing options...
icegrill Posted May 19, 2008 Share Posted May 19, 2008 What about a drop in perrin or avo filter and perrin afta maf hose? Which filter would everyone recommend? Link to comment Share on other sites More sharing options...
fonts Posted May 19, 2008 Share Posted May 19, 2008 Don't think there is a huge difference between AVO and Perrin panel filters. Have seen members rant about both. I was running a Perrin panel filter and it worked well for me. Also purchased the Perrin AFTA MAF hose. Have since replaced both. My opinion on the MAF hose is to save your money unless you are planning doing additional engine mods. Just my .02 Link to comment Share on other sites More sharing options...
