g2redgsr Posted May 18, 2008 Share Posted May 18, 2008 rustoleum makes that right? Link to comment Share on other sites More sharing options...
hutru01 Posted May 18, 2008 Share Posted May 18, 2008 a gutted downpipe and an STi uppipe shouldnt throw any red flags at the dealer. u can even unmarry your AP before you go in. This is exactly what I was going to say. The dealership will never know that you gutted your downpipe and put in the sti/bosal uppipe. Anytime you need to take it in, just flash to stock. What they don't know won't hurt them or your warranty. Link to comment Share on other sites More sharing options...
g2redgsr Posted May 18, 2008 Share Posted May 18, 2008 if you flash back to stock you wont throw a code either? Link to comment Share on other sites More sharing options...
hutru01 Posted May 18, 2008 Share Posted May 18, 2008 If you unmarry the AP and take it easy on the way to the dealership, you shouldn't have any problems. Its when you go WOT that it might throw a code. Just stay out of boost. Link to comment Share on other sites More sharing options...
g2redgsr Posted May 18, 2008 Share Posted May 18, 2008 i see... Link to comment Share on other sites More sharing options...
AKLGT Posted May 18, 2008 Share Posted May 18, 2008 If it's just regular service, your normal service tech isn't even going to hook up any kind of engine diagnostic machine to the car. just go stg 2 with gutted UP, DP (leave one cat in there Just in Case). Flash the AP to econo mode so it won't boost high and even if they take it out for a spin, they probably won't know the difference unless you go completely catless and it stinks. if they don't ask, don't tell them. you're not lying (don't lie to your techs or they will be much less willing to help you out should something go bad), you're just not giving out info either. Wiggle wiggle wiggle wiggle wiggle yeah!!! Link to comment Share on other sites More sharing options...
g2redgsr Posted May 18, 2008 Share Posted May 18, 2008 which cat should i leave when i do this? + anyone got the thread to gutting the dp i cant find it but i know ive seen it. Link to comment Share on other sites More sharing options...
AKLGT Posted May 18, 2008 Share Posted May 18, 2008 mid pipe. and you just take the down pipe off and then use a hammer or something and knock the cat out. 15 mins and you're done. here you go: http://www.legacygt.com/forums/showthread.php?t=84688 Wiggle wiggle wiggle wiggle wiggle yeah!!! Link to comment Share on other sites More sharing options...
g2redgsr Posted May 18, 2008 Share Posted May 18, 2008 does it come out in one piece? would be lovely to find some pics but even if i found them they wouldnt work anymore my luck lol...thanks for the help ak Link to comment Share on other sites More sharing options...
CMull123 Posted May 18, 2008 Share Posted May 18, 2008 If I gut the stock DP, could I go cobb stage 2? Link to comment Share on other sites More sharing options...
hutru01 Posted May 18, 2008 Share Posted May 18, 2008 ^ Definitely, but if you have an 05, you might as well gut the UP as well while your at it. Link to comment Share on other sites More sharing options...
Richard B. Posted May 19, 2008 Share Posted May 19, 2008 voiding a warranty on a 2005 LGT wagon 5EAT? (extended warranty) If possible, what is that way? I really want to go stage 2 so bad. technically...go get a stage 1 dyno/road protune. it will most likely be higher than a ots stage 2 cobb map. no hardware and just uninstall for dealer service. Link to comment Share on other sites More sharing options...
AKLGT Posted May 19, 2008 Share Posted May 19, 2008 ^ Definitely, but if you have an 05, you might as well gut the UP as well while your at it. I wouldn't go stg 2 on a gutted DP only. bare minimum, you should have catless UP and DP, possibly keep the mid pipe catted. Wiggle wiggle wiggle wiggle wiggle yeah!!! Link to comment Share on other sites More sharing options...
CMull123 Posted May 19, 2008 Share Posted May 19, 2008 I have an aftermarket catless UP. It was cheaper than the DP. Link to comment Share on other sites More sharing options...
lawl Posted May 19, 2008 Share Posted May 19, 2008 i've heard some stories (verified if you search) that the pre turbo cat broke apart got sucked into the turbo and broke the turbo. also theres SOME added performance benefit to a catless uppipe. I dont understand why people would shy away from it.. i think slightly faster spool and something else that i can't remember. car for sale. PM me! Link to comment Share on other sites More sharing options...
whobaru Posted May 19, 2008 Share Posted May 19, 2008 People shy away from it because it's a bitch to install. Link to comment Share on other sites More sharing options...
iahtnoob Posted May 19, 2008 Author Share Posted May 19, 2008 will an uppipe from a 06 STi work for my 05 LGT and also what kind of dp do i need? thanks Link to comment Share on other sites More sharing options...
executor485 Posted May 19, 2008 Share Posted May 19, 2008 Yes, any STi up will/should fit your car. I just did it with an 04 STi up, it took a whole 5.5 hours and that was with about 45min of engine cooldown and I used a lift/stall at the auto hobby shop here on base. As for voiding the warranty, the dealership probably wont cover the problem... BUT, if you use an STi up, it looks stock so you can probably get away with that, or just gut your stocker and put it back in. As for the DP, I just gutted the stock (funding, not warranty driven) and used the STi up... Its great! It also looks stock, so dealerships probably wouldnt hassle you too much if something went bad, unless they really went to town and did a lot of checking/work to find out. As for the AP, if you have any issues, just set it back to stock, keep the AP at home so they dont see it, and have them check it out, maybe buy a non-gutted DP so that you can change it back quickly before you go in. Oh, one thing I did remember, I did have to do the resistor mod with the STi up... And the dealership would notice that... But you should do the resistor mod even if you gut your OEM up... Dont want your EGT to break up and go into the turbo and screw it up. If I pass you on the right, I'm flipping you off. Link to comment Share on other sites More sharing options...
AKLGT Posted May 20, 2008 Share Posted May 20, 2008 I didn't have to do any resistor mod on my gutted stocker. Never had a CEL either. Wiggle wiggle wiggle wiggle wiggle yeah!!! Link to comment Share on other sites More sharing options...
whobaru Posted May 20, 2008 Share Posted May 20, 2008 noted...didn't you run an Sti UP at some time? ...or is it the gutted stocker PDX is gonna do whatever with. PS I still want it. Link to comment Share on other sites More sharing options...
lawl Posted May 20, 2008 Share Posted May 20, 2008 I didn't have to do any resistor mod on my gutted stocker. Never had a CEL either. accessport clears that CEL. car for sale. PM me! Link to comment Share on other sites More sharing options...
iahtnoob Posted May 20, 2008 Author Share Posted May 20, 2008 so i can use the sti upipe and not have to do the resistor mod, correct? Link to comment Share on other sites More sharing options...
iahtnoob Posted May 20, 2008 Author Share Posted May 20, 2008 If it's just regular service, your normal service tech isn't even going to hook up any kind of engine diagnostic machine to the car. just go stg 2 with gutted UP, DP (leave one cat in there Just in Case). Flash the AP to econo mode so it won't boost high and even if they take it out for a spin, they probably won't know the difference unless you go completely catless and it stinks. if they don't ask, don't tell them. you're not lying (don't lie to your techs or they will be much less willing to help you out should something go bad), you're just not giving out info either. and so i don't need to do anything to my stock downpipe? Link to comment Share on other sites More sharing options...
hutru01 Posted May 20, 2008 Share Posted May 20, 2008 The stock downpipe has 2 cats if IIRC. She is saying to leave one just to be safe....not a bad idea because you might get some smelly if you go 100% catless. Link to comment Share on other sites More sharing options...
executor485 Posted May 20, 2008 Share Posted May 20, 2008 Exactly. Stock DP has 2 cats. Gut the one closest to the turbo and leave the other one. Its REALLY easy, I had my doubts and worries, but its a breeze honestly... Just print out the directions from the up pipe removal thread and follow them, its great If I pass you on the right, I'm flipping you off. Link to comment Share on other sites More sharing options...
