iahtnoob Posted May 17, 2008 Share Posted May 17, 2008 voiding a warranty on a 2005 LGT wagon 5EAT? (extended warranty) If possible, what is that way? I really want to go stage 2 so bad. Link to comment Share on other sites More sharing options...
BigBad Posted May 17, 2008 Share Posted May 17, 2008 You gotta be willing to pay to play as stage 2 mods are rather obvious to the dealer. Some dealers will look the other way and others won't. Your warranty can't be voided but if you bring the car in for a problem and they feel a mod contributed or caused the failure then they may refuse to cover it. Link to comment Share on other sites More sharing options...
CMull123 Posted May 17, 2008 Share Posted May 17, 2008 Unless you have a cool dealer, no. Basically stage 2 is better exhaust overall, downpipe and more. What you could do, is go stage 2, and then everytime you take it in to have anything done - ANYTHING - take everything out of the car and put it all back in when you get it back. It'd be fun. In a year or so, you'd prolly be the fastest downpipe installer in the world. Link to comment Share on other sites More sharing options...
gfxdave99 Posted May 17, 2008 Share Posted May 17, 2008 Also it depends on your definition of stage 2. Usually stg 2 is UP/DP/Catback/Flash. However i think where they really start saying no dice if you have engine problems is the flash. A local North Central member had his turbo go out under the factory warranty, he had an UP/DP and aftermarket cans but no catback and they replaced the turbo under warranty. There are mod friendly dealers and there are not. The deal is if something breaks they have to demonstrate that your modification contributed to the problem. If you have a stock suspension and are stage 2 with flash but you have a wheel bearing go bad, it would be pretty hard to say that stage 2 power caused it to go bad. However if you have aftermarket springs and your camber and toe in was borked I would say the dealer is totally in the right to tell you that you are out of luck on warranty coverage. If everything seems under control, you're just not going fast enough. - Mario Andretti Link to comment Share on other sites More sharing options...
CMull123 Posted May 17, 2008 Share Posted May 17, 2008 My syncros are goin out in all gears and my dealer said it was because my AP, which at the time was the ONLY mod. My opinion is that it all depends on the cost. After they denied my tranny claim, my fan was cycling all the time. I took it in and they said they had to replace my ECU and had no problems doing so. The tranny woulda been ~$2500, the ECU was only ~$600. If you ask me, the tranny goin out had probably NOTHING to do with the AP, on the other hand, they coulda said my AP was the ONLY reason the ECU went bad. Shysters are just tryin to save a penny. P.S. The spell checker knows the word shysters. Link to comment Share on other sites More sharing options...
Impulse Posted May 17, 2008 Share Posted May 17, 2008 2005 ECU had a recall on it due to some fan relay breaking it, the primary symptom was fans running all the time... anyone got the TSB on hand? Link to comment Share on other sites More sharing options...
whobaru Posted May 17, 2008 Share Posted May 17, 2008 voiding a warranty on a 2005 LGT wagon 5EAT? (extended warranty) If possible, what is that way? I really want to go stage 2 so bad. Nice try. Link to comment Share on other sites More sharing options...
BigBad Posted May 17, 2008 Share Posted May 17, 2008 2005 ECU had a recall on it due to some fan relay breaking it, the primary symptom was fans running all the time... anyone got the TSB on hand? http://www.thel7.com/tsb.html For all your TSB needs... Link to comment Share on other sites More sharing options...
fonts Posted May 17, 2008 Share Posted May 17, 2008 Nice try. I agree. The difference to stage II is incredible. Problem is that if you want the performance you are pretty much guaranteed that you won't have the extended warranty coverage. Is the tradeoff worth it for YOU is the dilemma???? Link to comment Share on other sites More sharing options...
iahtnoob Posted May 17, 2008 Author Share Posted May 17, 2008 Stage 2 can just be the flash and a downpipe right? Link to comment Share on other sites More sharing options...
fonts Posted May 17, 2008 Share Posted May 17, 2008 If you are running the stock 05 UP you will need to swap that out as well. In any case it might be a good idea to get a catless UP. Some members have experienced issues from the cat breaking up and spitting pieces into the turbo. You can generally find some pretty good prices used in the member classified section. Good luck. Link to comment Share on other sites More sharing options...
BlackHole Posted May 17, 2008 Share Posted May 17, 2008 OP - you're missing the point - you can have a guaranteed warranty or more power. Pick one and accept the loss of the other. Kyle "BlackHole" Link to comment Share on other sites More sharing options...
fonts Posted May 17, 2008 Share Posted May 17, 2008 OP - you're missing the point - you can have a guaranteed warranty or more power. Pick one and accept the loss of the other. Well put .... whatever you decide. Link to comment Share on other sites More sharing options...
iahtnoob Posted May 17, 2008 Author Share Posted May 17, 2008 so i'm gonna go UP and DP. Screw the damn warranty. Any recommendations for brand? I want to go catless UP correct. What is the gutted UP? Is the STI UP catless? I read that the STI is close to stock. DP should be simple i suppose. Thanks for the help fellow members. Link to comment Share on other sites More sharing options...
fonts Posted May 17, 2008 Share Posted May 17, 2008 Most aftermarket UP are catless. Gutted UP is the OEM UP where you gut the cat. I believe that there is information on this in the Walkthrough sections. I'm pretty sure the STi UP is catless. You won't be disappointed going Stage II. Link to comment Share on other sites More sharing options...
whobaru Posted May 17, 2008 Share Posted May 17, 2008 Most aftermarket UP are catless.all Gutted UP is the OEM UP where you gut the cat.PITA...you're better off buying one I'm pretty sure the STi UP is catless.Yes You won't be disappointed going Stage II.Nope Link to comment Share on other sites More sharing options...
g2redgsr Posted May 17, 2008 Share Posted May 17, 2008 ive heard of people covering breakdowns through insurance...mostly hydrolocking from what i heard of, anyone think thats a possibility? Link to comment Share on other sites More sharing options...
rabydanimal Posted May 18, 2008 Share Posted May 18, 2008 You gotta be willing to pay to play as stage 2 mods are rather obvious to the dealer. Some dealers will look the other way and others won't. Your warranty can't be voided but if you bring the car in for a problem and they feel a mod contributed or caused the failure then they may refuse to cover it. Not true... I used a gutted up pipe/down pipe for my stg II setup just for that reason. Throw a SPT exhaust on there and they'll have no reason to deny your claims should they come up. Sure there are other ways to find out that you're not stock (something might tip them off when they drive it...) but most won't care as long as they don't see blingy aftermarket pipes. Link to comment Share on other sites More sharing options...
CMull123 Posted May 18, 2008 Share Posted May 18, 2008 ^ I wish my dealer were cool at all about it. They bitched when I put in halo's. Link to comment Share on other sites More sharing options...
SubLGTaru Posted May 18, 2008 Share Posted May 18, 2008 I notice you are from Indiana. What dealer do you go to? I go to the Fort Wayne Acura Subaru. Haven't found out if they are mod friendly or not. Link to comment Share on other sites More sharing options...
BigBad Posted May 18, 2008 Share Posted May 18, 2008 Not true... I used a gutted up pipe/down pipe for my stg II setup just for that reason. Throw a SPT exhaust on there and they'll have no reason to deny your claims should they come up. Sure there are other ways to find out that you're not stock (something might tip them off when they drive it...) but most won't care as long as they don't see blingy aftermarket pipes. If that has been your experience then that is good to know but I have seen/heard otherwise from dealers in the area. As well for those of us that prefer not to run completely catless for a variety of reasons it makes it a bit more difficult. Link to comment Share on other sites More sharing options...
CMull123 Posted May 18, 2008 Share Posted May 18, 2008 I goto Gurley Leep Subaru in Mishawaka. Ft. Wayne is the next closest but I'm not driving 2 hours for a oil change. I wish I were a little closer, I hate Gurley Leep. Link to comment Share on other sites More sharing options...
lawl Posted May 18, 2008 Share Posted May 18, 2008 a gutted downpipe and an STi uppipe shouldnt throw any red flags at the dealer. u can even unmarry your AP before you go in. gutted downpipe looks exactly the same as before. 07 and 08 LGTS already have a catless Uppipe. not sure if these are the same as the sti uppipe but if you take one from the 07 and put it in ur car i'm pretty sure the dealer wont even know the difference. there is no way to tell until the dealer pulls these parts off and looks inside for the cat. car for sale. PM me! Link to comment Share on other sites More sharing options...
g2redgsr Posted May 18, 2008 Share Posted May 18, 2008 changed my oil last night for the first time...was looking at the bolts for the up-pipe/down pipe and theyre pretty rusty....it would prolly be noticeable if i had to replace all those bolts no? Link to comment Share on other sites More sharing options...
lawl Posted May 18, 2008 Share Posted May 18, 2008 changed my oil last night for the first time...was looking at the bolts for the up-pipe/down pipe and theyre pretty rusty....it would prolly be noticeable if i had to replace all those bolts no? lol paint the new ones a rusty color car for sale. PM me! Link to comment Share on other sites More sharing options...
