bluesuby Posted December 12, 2009 Share Posted December 12, 2009 Yakker , You said spec B bushings are they different than the GT's? I have a 06 spec B and it looks to me like my bushing is cracking there I assumed we had the same ones until I read your post. TIA, Anthony Good question. You would think the performance version would get more robust components where possible. Link to comment Share on other sites More sharing options...
ama0787 Posted December 13, 2009 Share Posted December 13, 2009 I only asked because Yakker specifically mentioned ordering the spec b bushing for his GT I find this strange b/c I thought we had the same bushing and I am actually worried my bushing is cracked and in need of replacement Link to comment Share on other sites More sharing options...
bluesuby Posted December 13, 2009 Share Posted December 13, 2009 I only asked because Yakker specifically mentioned ordering the spec b bushing for his GT I find this strange b/c I thought we had the same bushing and I am actually worried my bushing is cracked and in need of replacement Exactly. Why replace a bad part with another bad part? Link to comment Share on other sites More sharing options...
ifbiker Posted December 14, 2009 Share Posted December 14, 2009 I believe the spec B and current WRX are the same bushing, a quick call to the Subie dealer will confirm. If they are different you can use current WRX bushings or go to group N which can be purchased through Rallispec. I used the group N becuase they were more stiff than the WRX bushings. While you are replaceing the LCA bushing, besure to replace the smaller front bushing with either group N or current WRX. The LGT bushing is very compliant. Link to comment Share on other sites More sharing options...
yakker Posted December 17, 2009 Share Posted December 17, 2009 Yakker , You said spec B bushings are they different than the GT's? I have a 06 spec B and it looks to me like my bushing is cracking there I assumed we had the same ones until I read your post. TIA, Anthony Hi Anthony, I was told the Spec B bushings "might" be different than the Legacy stockers. I did not confirm this since the part I ordered was not the correct bushing to begin with. The vendor and I were talking about two different bushings. I gave up the Spec B search, and was able to track down a set of non-offset SuperPro bushings from another vendor. Unfortunately, I can't remember where I found them, but they have been working well with no tears for over a year. Link to comment Share on other sites More sharing options...
BrownBoy Posted December 17, 2009 Share Posted December 17, 2009 I believe the spec B and current WRX are the same bushing, a quick call to the Subie dealer will confirm. If they are different you can use current WRX bushings or go to group N which can be purchased through Rallispec. I used the group N becuase they were more stiff than the WRX bushings. While you are replaceing the LCA bushing, besure to replace the smaller front bushing with either group N or current WRX. The LGT bushing is very compliant. I was just doing some research into the front (smaller) bushings. Whiteline looks to have a poly replacement for the Legacy now. http://www.whiteline.com.au/product_detail.php?part_number=W0506 Link to comment Share on other sites More sharing options...
ama0787 Posted December 18, 2009 Share Posted December 18, 2009 i think that is a different bushing probably goes in the place where the re is a vertical pivot point.. I replaced all control arm bushings in my supra and that is mainly what they looked like. I really dont hink taht could fit where our large bushing is that tears any bushing replacing that one would have to fill the id of the hole one way or another Link to comment Share on other sites More sharing options...
wpmarky Posted December 19, 2009 Share Posted December 19, 2009 spec.b stock bushins are soft, they were the first things i replaced. Link to comment Share on other sites More sharing options...
Guest Posted December 19, 2009 Share Posted December 19, 2009 Hi Anthony, I was told the Spec B bushings "might" be different than the Legacy stockers. I did not confirm this since the part I ordered was not the correct bushing to begin with. The vendor and I were talking about two different bushings. I gave up the Spec B search, and was able to track down a set of non-offset SuperPro bushings from another vendor. Unfortunately, I can't remember where I found them, but they have been working well with no tears for over a year. They are different. They are same as on 08+ STI. Seem to be touch stiffer and less prone to tearing. Link to comment Share on other sites More sharing options...
D_J Posted December 19, 2009 Share Posted December 19, 2009 FWIW, I gave up on looking for non-offset bushings and ordered a set of Spec B bushings from www.subarupartswarehouse.com . I'll report back and let you guys know if there is actually any difference from the cracking tennis ball versions. For $40, it's a cheap shot in the dark. I would have gone with the AVO offsets, but my OBXTs wheels have no room in the well to move further forward since the wheel/tire combo fills more of the gap in the well, and the wheels have a forward well bias to begin with. You can try these from Perrin: http://www.perrinperformance.com/products/show/743/Anti-Lift-Kit-PSRS-ALK-Zero-Deg- Regarding our Outbacks...I read that we have spacers in the LCA bushing mounts (to add height?) but apparently these are still compatible. Link to comment Share on other sites More sharing options...
bluesuby Posted December 19, 2009 Share Posted December 19, 2009 You can try these from Perrin: http://www.perrinperformance.com/products/show/743/Anti-Lift-Kit-PSRS-ALK-Zero-Deg- Regarding our Outbacks...I read that we have spacers in the LCA bushing mounts (to add height?) but apparently these are still compatible. That looks like a fine product and I really don't want to change the caster settings on my car. They are pricey compared with stock, but is their a discount source in lieu of ordering directly from Perrin? Link to comment Share on other sites More sharing options...
