phil.p Posted May 2, 2008 Share Posted May 2, 2008 Hi Guys, > > Subarau Legacy 2.0L '98 UK > The car has 100k miles on the clock generally in good 'condition > regular services etc.The car drives well in normal traffic > conditions every day typically normally 50 miles max speed 50mph-70mph country lanes > Recently I have noticed that after driving on the motorway(speeds of > 70 to 80 mph for greater than 1 hour, when I come off on the slip > road the temp gauge fluctuates very close to the high mark (normally > it is rock steady mid point). Car performances is normal and no > other dash lights come on. > Discussion with colleagues has suggested either hot spots in the > engine (not sure what this means) or electrical problems associated > with the signal sender. > I have had the thermostat recently repalced as my garage thought > this could be the problem but it was not. Any ideas:iam: > Link to comment Share on other sites More sharing options...
ehsnils Posted May 2, 2008 Share Posted May 2, 2008 Bad temperature sensor or bad contact. If replacing the sensor doesn't help I suggest that you try to add a secondary temperature gauge temporarily to check if it's the temperature that's really a problem or if you have a problem with your gauge (or other electronics). Link to comment Share on other sites More sharing options...
