starhm Posted July 19, 2009 Share Posted July 19, 2009 (edited) just got mine apart. took two and a half hours of slow fun. the blue clip in the center has two push to releases one on each side. all three of them (two white and one blue) rattled like hell in the hole. also, all of my vent ducting attached to the underside of the dashboard rattled against other ducting parts. I will try to get some pics to explain that last one, but the rattles were at the center and drivers vents. i have to go and get an air filter while the glove box is out and some cloth tape to finish up. also, about three or four clips broke on manufacture. dont get it. i got the car four months old used... dont know what else could have done it. those loose pieces were rattles as well. Edited July 21, 2009 by starhm Link to comment Share on other sites More sharing options...
tdoggydog Posted July 21, 2009 Share Posted July 21, 2009 I just used foam and double side tape. As of today, the car is still rattle free ever since I removed the dash. No need to add insulation or whatever. The foam type is just some soft foam from home depot. Actually, anything you find that can eliminate that "plastic against plastic" noise, you are good. nope, just regular screw drivers I don't remember correctly, but there aren't that many screws to hold up the gauge. As for the plastic cover, make sure you REMOVE the plastic cover, take it out from the top hole of the steering wheel, and then remove the gauge. The ENTIRE gauge including the plastic cover will NOT come out (I tried) hope this helps. I did NOT regret taking it apart at all, and the car is STILL rattle free from the dash Where do you live? Can I pay you to do this for me? Link to comment Share on other sites More sharing options...
starhm Posted July 21, 2009 Share Posted July 21, 2009 (edited) got it back together last night and drove it to work today. no rattles. you are the man witht his thread. for the instrument cluster, once you remove the pieces under the steering column and the metal plate behind that, you can look up at the bottom of the instrument cluster and there are two small screws up there that go into the bottom of the cluster. after all three screws were out, I put a towel on the top of the column and pulled the cluster forward and disconnected the two wire harnesses on the back. this gave me enough room to move the cluster side to side to get the two screws out behind the cluster. I left the cluster sit there wrapped in an old t shirt until the dash was completely loose then lifted up on the dash to get the cluster out. make sure to protect the face while it is waiting for removal. i already had the vents and radio out before the cluster, so i had good access for moving it around. during installation, i set the dash in place then raised it up enough to get the cluster back in. Thanks again for all the help this thread provided!! Edited July 21, 2009 by starhm Link to comment Share on other sites More sharing options...
jproy12 Posted February 24, 2010 Share Posted February 24, 2010 I'll be doing this soon! My dash rattles like crazy!! JP Link to comment Share on other sites More sharing options...
christurismohk Posted February 24, 2010 Author Share Posted February 24, 2010 Starhm: Good to hear you got the rattles gone!! I did this back in 08, and the dash has been dead quiet since then!! The plugs in the firewall hole was the killer, and TSB did not address that. jproy12: Good luck man! But you won't regret with the result. Like the title said, taking it apart is the correct way of fixing it. Link to comment Share on other sites More sharing options...
jproy12 Posted March 10, 2010 Share Posted March 10, 2010 Now 100% less rattle!! WooHoo!!! Took alot of time, more than expeceted, but really took my time and rewires a couple wires from my alarm system! What i did is epoxied the 3 plastic parts into the firewall, and let it dry for an hour before putting back in everything!! Hope its going to last!! And what a difference!! JP Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted March 10, 2010 Share Posted March 10, 2010 got my dash off anyways, great thread here. If you have the vacation pics, it's easy. It was a pain by myself to move the heavy dash, but with 2 people it would be no problem. I figure 1.5 hours to remove it if you just go at it. [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
jproy12 Posted March 10, 2010 Share Posted March 10, 2010 got my dash off anyways, great thread here. If you have the vacation pics, it's easy. It was a pain by myself to move the heavy dash, but with 2 people it would be no problem. I figure 1.5 hours to remove it if you just go at it. Sounds about right, i took my time, and well took most of the day, started at 9am and finished at 3pm, but took a 2.5hour break and rewired some wires from my alarm system! The screws that i was having trouble finding where the ones under the passenger side dash (for the airbag) after that, bingo everything went smooth! Here are some pics of my dash at it! http://i729.photobucket.com/albums/ww296/jproy12/SUC50607.jpg http://i729.photobucket.com/albums/ww296/jproy12/SUC50606.jpg http://i729.photobucket.com/albums/ww296/jproy12/SUC50605.jpg http://i729.photobucket.com/albums/ww296/jproy12/SUC50604.jpg http://i729.photobucket.com/albums/ww296/jproy12/SUC50603.jpg http://i729.photobucket.com/albums/ww296/jproy12/SUC50602.jpg http://i729.photobucket.com/albums/ww296/jproy12/SUC50601.jpg http://i729.photobucket.com/albums/ww296/jproy12/SUC50600.jpg http://i729.photobucket.com/albums/ww296/jproy12/SUC50608.jpg Hope this will help some of you also! Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted March 10, 2010 Share Posted March 10, 2010 Sounds about right, i took my time, and well took most of the day, started at 9am and finished at 3pm, but took a 2.5hour break and rewired some wires from my alarm system! The screws that i was having trouble finding where the ones under the passenger side dash (for the airbag) after that, bingo everything went smooth! That's exactly why I actually took mine off. It's so much easier to run wires properly with it gone. Not necessary, but definitely my preference. Those two bolts under the pass side airbag took me a while to find even with the vac pics. But yeah, those and a few harnesses and it was off. [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
christurismohk Posted March 21, 2010 Author Share Posted March 21, 2010 Very nice jproy12!! Like I said, those clips on the firewall is making the noise. I have no idea why the TSB did not address this......... TSB only did half the job. Link to comment Share on other sites More sharing options...
jproy12 Posted March 21, 2010 Share Posted March 21, 2010 Very nice jproy12!! Like I said, those clips on the firewall is making the noise. I have no idea why the TSB did not address this......... TSB only did half the job. Sure was a great thing to do!! Dont regret it at all! JP Link to comment Share on other sites More sharing options...
maddoc Posted March 23, 2010 Share Posted March 23, 2010 Hm, I wonder if I could fix mine when my windshield gets replaced, and not have to take out the dash completely Link to comment Share on other sites More sharing options...
ssbtech Posted April 19, 2011 Share Posted April 19, 2011 so...I have tried just about everything, and cannot find the solution. I jammed a bunch of cut rubber spacer down in between the windshield...but it didnt help a bit. this is what you guys are hearing too, right? I know this is old, but worth a shot if you're still having the buzzing - The fuel lines in the engine bay. Happened on mine. A zip tie around the three lines, not too snug but just snug enough to stop them from vibrating should fix this. Just after where they poke through the firewall. Solved it for me. Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted April 19, 2011 Share Posted April 19, 2011 good tip! [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
ssbtech Posted April 19, 2011 Share Posted April 19, 2011 It didn't quite sound like the same buzz, but I had it on mine. When I downshifted and began to slow down it would buzz like crazy at around 3,000RPM. i didn't like the idea of ties around the fuel lines so it's not tight, just enough to change the frequency which they vibrate at. Link to comment Share on other sites More sharing options...
AkumaMax Posted April 20, 2011 Share Posted April 20, 2011 Audi I believe?!?!?!?! Flavio Zanetti Boston, MA Same Car! Link to comment Share on other sites More sharing options...
alanztalon Posted April 20, 2011 Share Posted April 20, 2011 yeah, it is still going on. so weird that is is completely temperature related. in winter, when it is below say 60 degrees, the sound is gone completely. only when the weather warms up. i will be back to monkeying with it no doubt. i will definitely investigate the fuel lines..i am not sure where they would enter the firewall from inside the engine bay. from below? very annoying. Link to comment Share on other sites More sharing options...
jproy12 Posted April 29, 2011 Share Posted April 29, 2011 Alright, I'm doing this again this weekend with a bunch of guys (all local members) We will do a how-to with all bolts and nuts to remove and all! JP Link to comment Share on other sites More sharing options...
Scooby2.5 Posted April 29, 2011 Share Posted April 29, 2011 ^cool that would be great thanks Link to comment Share on other sites More sharing options...
jproy12 Posted April 29, 2011 Share Posted April 29, 2011 ^cool that would be great thanks Indeed.. I've done 2 dash in the past, mine which has been over a year and nothing and a friend of mine, and aiming to do another 5-7 this weekend!! I'll have my share of dash rattle!! Pics to come with a good "how-to" JP Link to comment Share on other sites More sharing options...
jproy12 Posted May 1, 2011 Share Posted May 1, 2011 We finally did 4 dash yesterday! Will post pics and a how-to with lots of details! JP Link to comment Share on other sites More sharing options...
Scooby2.5 Posted May 1, 2011 Share Posted May 1, 2011 4 different cars? Link to comment Share on other sites More sharing options...
jproy12 Posted May 1, 2011 Share Posted May 1, 2011 4 different cars? Yup! 4 Different Legacy's!! Link to comment Share on other sites More sharing options...
bigleben Posted May 2, 2011 Share Posted May 2, 2011 Really worth the long drive for the ±3hr dash rattle fix !! Link to comment Share on other sites More sharing options...
carguyco Posted September 11, 2011 Share Posted September 11, 2011 where are those 4 legacy pics? Link to comment Share on other sites More sharing options...
