Scrim Posted April 24, 2008 Posted April 24, 2008 I have an 07 LGT with the nav system. I am having difficulty in getting the clock in my gauge cluster to read 12 hour time, it reads 24hr (military) time. I can get into the clock set application in the nav system, and when I set a new time it will change the clock in the guage cluster. But when I set it for either 12 or 24 hour mode, the other clock won't change. What I am doing wrong?
Scrim Posted April 24, 2008 Author Posted April 24, 2008 The manual says to use the nav system for setting both clocks. I tried to use the stick, but it only presses to change modes and does not twist like on older subarus. I read somewhere that if you press in the stick within 30 seconds of starting the car that it would go into a "set mode," but that isn't the case either.
Throttlejockey Posted April 26, 2008 Posted April 26, 2008 I tried and couldn't get it to work even after setting it.. It always went to military time after 12:00
finboy Posted May 12, 2008 Posted May 12, 2008 anyone figure how to get the dash clock to read in 12hours?
Jon in CT Posted May 12, 2008 Posted May 12, 2008 anyone figure how to get the dash clock to read in 12hours?The dash clock will only display military time. There is no way to change this.
finboy Posted May 12, 2008 Posted May 12, 2008 ;1875633']The dash clock will only display military time. There is no way to change this. 10-4 kinda ghay though (picked up a 07 spec B) still trying to figure out the nav system tks for the help dave ps. is there a way to change the info on the dash eg. if i wanted to display the clock and outside TEMP??
EquinnoxX Posted May 13, 2008 Posted May 13, 2008 ps. is there a way to change the info on the dash eg. if i wanted to display the clock and outside TEMP?? Not that I know of. But you can display both the time and the outside temp on the navi screen. There is a 'trip meter hacking thread' but i don't think anything solid has been done yet: http://legacygt.com/forums/showthread.php?t=79982
