headlight bulb/ moisture question
Posted
my right low beam just took a crap on me, that side get a good bit of moisture in it. i don't see any cracks, nor do i know if the previous owner took it apart before...
once moisture gets in, is it possible to clean it while replacing the bulb and then put it back together without the moisture coming back?
Posted
alrighty, i've just read how to do it...
i didn't see anything on the fixing of the moisture, if i need a new housing then i need one, but if it can be fixed.... well i'd rather fix it
also, what a good replacement bulb?
