Is this what I think it is?
SpecBee
Posted
I have the same wire in my 08 Spec B. I am assuming that is for the OEM sub. I havent opened the install doc for the 08 yet to see where the harness is at...But I would put 2 & 2 together.
Posted
Yea, I was getting ready to run wires from the HU to under the seat for a sub and removed the pass seat to find that harness. I believe it's the same as the GTs without the Nav but it is located on the drivers side. Now I just have to find a connecting harness and wiring diagram or ring it out. Anyone have info on that plug? It did have a pink wrap of tape not blue...I do have an 08 with Nav.
Posted
Was it taped up and tucked right next to one of the floor vents under the seat? If so, that might be the connector for the optional Perimeter Alarm (Shock Sensor). I haven't heard of the cars being pre-wired for the OEM sub.
Posted
I'm pretty sure the factory sub goes under the drivers seat. If you don't have heated seats it could be for that.
Posted
This sucks. It probably is for the alarm due to it being pink tape. Looks like im back to wiring into the high level outs for the ReQ and sub. I was excited that I found that plug and put the stereo back together and closed everything up.
Posted
Correct, the LGTs are not pre-wired from the factory. On the back of the radio there is a spot to plug in the factory sub harness. Plus the sub is installed under the driver side seat.
My wife's balls are delicious.
Posted
the nav unit is underneath the drivers seat, no room for a sub there FYI
