rotor thickness
Th3Franz
Posted
The minimum thickness is cast into the rotor. If I remember correctly it is on the inside of the rotor, the outermost ring of the hub area next to the inner rotor face. It's probably about 28mm min, but you should double check with any shop that turns rotors to verify specs.
Kyle "BlackHole"
Posted
Front disk- mm (inches) width max - min
15″ disk 24(0.94) 22 (0.87)
16″ disk 24 (0.94) 22 (0.87)
17″ disk 30 (1.18) 28 (1.10
Rear disk MM(inches) max-min
Solid disc 10(0.39) 8.5 (0.335)
Ventilated disk 18(0.71) 16 (0.63)
"Belief does not make truth. Evidence makes truth. And belief does not make evidence."
