HID Install using factory grommet....post comments/pics here
croll326
Posted
If you have done an HID install and used the factory grommets post your comments, pics, and suggestions here. Thanks.
Im afraid that water/moisture will get in if i drill a huge hole in the plastic covers.
Posted
I have done both ways, and I recommend the factory grommet way. I have no pics, but it is very straight forward.
X
Posted
Hey everyone,
So, I figure that this would be a good place to ask, since it's one of the most recent "retro" threads. :)
I'm not doing a retro, but instead, working on the tail-light sections.
How "messy" is it going to get if I wanted to cut a bit of the "chromed" plastic reflector array, inside, say, the clear (reverse lamp) portion of the tail-light housing?
I'm afraid that it'll look really bad - that the chromed plastic surrounding the cut would just chip/crack....
Any advice?
<-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges
'16 Outback, '16 WRX, 7th Subaru Family
Posted
^ Ah....that's my problem....and I apologize for not having clarified earlier. :redface:
I am very reluctant to pull the lens off the back ( er...front? :lol: ) of the tail-light housing. So that'll prevent me from taping-off.
I am thinking that drilling/cutting, without pulling the lens, won't be possible - at least not if I wanted to be neat.
Thanks! :)
Posted
Every headlamp chrome reflector main part in all the lights i've messed with (hundreds) respond best to a dremel with a sanding bit when it comes to the final shaping / trim. No flaking and it looks like it was originally shaped that way when your done.
MAYHEM
#122/22 STS NNJR SCCA
AUTOX4U.COM
XENON RETRO GUIDE
Posted
^ Thanks, bruddah! :)
I've never tried trimming such areas before, so I was very, very hesitant to do so.
I'm going to purchase an el-cheapo e-bay headlamp unit to give this a practice go.
Thank you for both your encouragement as well as wisdom/tips! :D
Posted
Drilled a 1" hole in the middle of that big cover that gives access to the low beam bulbs, fed all the wires in, and the HIDs came with a rubber grommet that plugged up the 1" hole. looks OEM'ish.
