spring help...help!
xr7kid
Posted
I'd recently installed some konis and I've been getting a squeaking sound from the driver side rear area. I took everything apart again and it looks like the very end of the top coil is rubbing on the coil right below it, why is this and how can it be fixed? There a little bit of wear and rust build up so I'm pretty sure this is what is causing my problems. Is the tophat directional in some way and maybe I installed it the wrong way? I don't know, but it's all taken apart in the garage waiting on your anwers....:)
Posted
If you can post some pictures maybe I could help. No they are not directional.:)
p.s my 5yr old wanted me to put the :)
Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com
