PCV valve
Posted
Where is the PCV valve located on a 1994 2.0 twin turbo leggy?
What are the chances that cleaning the PCV will cure a heavy front of engine oil leak?
Posted
ummmm. If the oil is not leaking from where the valve is, then i highly doubt cleaning it will do anything. That's like washing your feet after you take a dump instead of wiping your ass.
Why not find out where the oil leak is coming from, then fix that?
Posted
It can't hurt to clean the PCV valve, if that helps it's good, if it doesn't you have wasted some time and got yourself dirty.
Of course - the leak may remain and have to be fixed even after the valve is cleaned.
But if an engine starts to shoot out various seals it may indicate that you have a more serious problem building up where the sealing between piston and cylinder is insufficient.
Posted
If you have a heavy leak from the front its the main seal or oil pump and cam seals.
Easy way to tell if its the oil pump and cam seals is if the inside of the timing belt cover has oil inside of it.
