nemo Posted February 29, 2008 Posted February 29, 2008 I can't seem to find an answer to this question. My windshield wiper fluid sprayers.... don't seem to spray at the right angle. There is no problem with the actual spraying, but rather where the fluid is getting sprayed on to. When I hit the spray button, the fluid gets sprayed on like the upper half of my windshield, and overshoots a little bit onto my sunroof. This leaves me with the upper half of my windshield clean, but the lower half is still pretty filthy... so I'll have to tap the button lightly a bunch of times to let the fluid barely squirt onto the lower portion of the windshield so it'll get cleaned. So, is there anyway to adjust the wiper fluid sprayers? If you don't vote Trump, out, you're a bigot who hates america.
PhilT Posted February 29, 2008 Posted February 29, 2008 Swap them out for ones with adjustable nozzles, the stock ones are crap. Double Award Winning Legacy GT Wagon
rao Posted February 29, 2008 Posted February 29, 2008 Sure Phil - he should get some STI ones The stock ones can be aimed; just use a pin and swivel them to where you want them to go. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT
nemo Posted February 29, 2008 Author Posted February 29, 2008 ^ Thanks, I took a look quickly but didn't really mess around with it. They seem to work fine other than the fact that they clean my sunroof If you don't vote Trump, out, you're a bigot who hates america.
PhilT Posted February 29, 2008 Posted February 29, 2008 Sure Phil - he should get some STI ones The stock ones can be aimed; just use a pin and swivel them to where you want them to go. Party pooper ! Double Award Winning Legacy GT Wagon
Jon in CT Posted March 2, 2008 Posted March 2, 2008 When I hit the spray button, the fluid gets sprayed on like the upper half of my windshield, and overshoots a little bit onto my sunroof. This leaves me with the upper half of my windshield clean, but the lower half is still pretty filthy... so I'll have to tap the button lightly a bunch of times to let the fluid barely squirt onto the lower portion of the windshield so it'll get cleaned. So, is there anyway to adjust the wiper fluid sprayers? Drive faster?
