APEXI 2.5i intake ruckus! with a samco sport hose!
Posted
just some wrx parts i had left over, here are some pics (cellphone)of it on the outback
http://i31.photobucket.com/albums/c376/FD13B/0226081249c.jpg
http://i31.photobucket.com/albums/c376/FD13B/0226081249b.jpg
http://i31.photobucket.com/albums/c376/FD13B/0226081249a.jpg
http://i31.photobucket.com/albums/c376/FD13B/0226081249.jpg
http://i31.photobucket.com/albums/c376/FD13B/0226081248.jpg
Posted
LT5PLA: sound's nice under load especially at high rpms
NickB34: the stock air filter box and intake hose are really the most restrictive parts due to them being designed to silence "air intake" and the ass dyno shows low end loss but high end gains just like any other short ram intake so go figure
JOE_1985: thank you for clearing that up! your 2 cents is more than appreciated
Posted
smushybrain: no need for brackets since the samco hose is so freakin stiff! no rattle or rubbing of any kind it doesn't move!
Alighieri256: haha ask Subaru..........
JayMitch2.5i: thank you sir!
Posted
LT5PLA: the maf pipe is made by APEXI
Viking067: thanks but like any other short ram intake they all take hot air from the engine bay if you want cold air then go with a CAI
  • 2 weeks later...
  • 1 year later...
Posted
lol yea whats the deal with that. but come on its not like we na guys have much to brag about. By the way nice short ram intake!
the deal is it will generate hot air from the engine not the cold air from outside...
sorry, I think this is a lame mod...:mad:
Posted
Are you sure that does much good?? All of the restriction is in the box that you connected it to...
That box isnt a restriction at all you only want to what this guy did at most on the MAF based N/A's should be good except i would try to get it ducted to the fender so you can get some type of cooler air versus the warm ambient engine bay air
Posted
MotherF!!!! How come the NA guys get an aluminum manifold and we have this cheap jank ass plastic POS?!?!
UM your cheap "jank" ass intake is less prone to heat soak than our cast intake manifold :)
Posted
I am actually considering placing phenolic spacers to dissipate heat soak as a result of my "great" aluminum intake manifold. So I guess you could say I envy your cheap "jank" ass plastic intake! ;)
Posted
Actually, I have tried""phenolic spacers"". Not much physical effects but caused turbulence and some flying idle after installation.
Also, the intake setup w/ the OEM torque box in front of TB is the best setup I've ever tried.
If you remove the OEM torque box and have the CAI connect onto TB directly, you will lose all your torque at low end.
Here is a setup I had before http://legacygt.com/forums/showthread.php?t=113305
Panson
Posted
Panson
Panson, two quick Q's for you:
1--Do you have photos of your CAI setup installed (& if not will you please post some?)
2--Did you use one gasket, two gaskets, or NO gaskets with your phenolic spacers? I know Rallitek recommends new gaskets on each side to sandwich the spacer in place. Was just trying think about why you had turbulence after install....
Posted
1. Sorry, I didn't even get a chance to take the pictures and my car got totaled because of the flood damage in my area (Houston, Texas)
If you search my old posts, I had done some crazy intake experiment and tried to find the best setup to achieve smooth revving w/o losing torque. So far the best I've found is to keep the OEM torque box and replace the OEM filter box w/ a CAI ( or short ram). Personally i prefer CAI because it gets to suck in more cold air and keep the car not so loud while revving up to the limit. BTW, I do use TB spacer to gain more torque in this setup.
2. I used 2 gaskets (bought it w/ the spacer). I really don't know why, but I can clearly feel some air turbulan is in my manifold whenever I stepped on the gas which also caused my idle to go up and down.
Panson
