what cambers are you guys running
team23jordan
Posted
auto cross season is just around the corner!!
what camber r u guys gonna run?
Perrin BIG maf intake
Perrin Turbo Inlet
HKS SSQV BOV
Megan Racing header with UP (ceramic coated)
HKS DP (WRX)
DMH E-cutout
Custom 3" catback
UTEC
Posted
Isn't -1.7 is too much with a wide tire like 245? I guess you should run flatter alignment.
Posted
-1.7 isnt too much. it all depends on where you want your grip, during cornering or under straight line braking. i choose under cordering since i like to trail brake alittle.
Posted
i'm thinking bout -1.5 front and -1 rear
Perrin Turbo Inlet
HKS SSQV BOV
HKS DP (WRX)
DMH E-cutout
Custom 3" catback
UTEC
Posted
-2.5 front and rear. This is the minimum negative camber recommended by Toyo for the R888.
From the Toyo set up specs:
Camber -2.5 up to -5.0:eek:
Caster - As much as possible:lol:
