Fosgate Posted February 22, 2008 Share Posted February 22, 2008 This should be stickied. http://www.japanparts.com/images/ImageFromDB.php?base=1&no=11153 It has been a while since I have been on, and I have scanned through the posts and have not seen this posted anywhere, and if it has been, then I appoligize. I have found a site that sells a double din dash kit with dual zone A/C. http://www.japanparts.com/db/parts_detail.php (if this doesn't work use next link) Half way down the page, part number: 107-209-006, Description: AV PANEL SET http://www.japanparts.com/db/partslist.php?dealer=1&car=7&middle=2&small=13 I have not tried this, however it does look tempting. They offer bother the single and dual zone climate control. Enjoy. Link to comment Share on other sites More sharing options...
lamw001 Posted February 22, 2008 Share Posted February 22, 2008 Good find but I've heard there would be problem between the degree F and degree C calibration. Unsure it's true or not tho. Link to comment Share on other sites More sharing options...
Fosgate Posted February 22, 2008 Author Share Posted February 22, 2008 I always assumed Japan was Degree C not F. It has a disclaimer that it MIGHT NOT work with USDM. Somebody needs to TOFTT. Link to comment Share on other sites More sharing options...
JonLGT Posted February 22, 2008 Share Posted February 22, 2008 :waits for someone else to try it first: Link to comment Share on other sites More sharing options...
ProjectSega Posted February 22, 2008 Share Posted February 22, 2008 Here's some info. I read previously somewhere in there that it doesn't work, but they could have a found a way. http://www.legacygt.com/forums/showthread.php?t=46539 http://www.legacygt.com/forums/showthread.php?t=49449 Hope that's some help Link to comment Share on other sites More sharing options...
lamw001 Posted February 22, 2008 Share Posted February 22, 2008 What holds the calibration for either the Degree C or F? ECU? Thanks for the links. AHRRR, read them all........it won't work!!! Sigh..... Link to comment Share on other sites More sharing options...
HighlineCA Posted February 22, 2008 Share Posted February 22, 2008 As a matter of fact, we have a tester unit coming to us for development. We believe it is possible it all works. Some trickery will need to be done to get it all to work. We will start a Development Study thread when the unit arrives and we get some solid answers. Stay Tuned! Rich @ HCA Link to comment Share on other sites More sharing options...
lamw001 Posted February 22, 2008 Share Posted February 22, 2008 ^^^^^Hey good new. Thanks Rich. Link to comment Share on other sites More sharing options...
whobaru Posted February 22, 2008 Share Posted February 22, 2008 Yes! I knew this would show up soon! *edit* How did I miss Unclemat's first thread?! I looked everywhere for this thing. Link to comment Share on other sites More sharing options...
whobaru Posted February 22, 2008 Share Posted February 22, 2008 um...the hazard switch hole is on the wrong side. This pic shows silver, other pics show black. I'm confused. http://i180.photobucket.com/albums/x312/kagenmateer/dashkit.jpg Link to comment Share on other sites More sharing options...
Fosgate Posted February 22, 2008 Author Share Posted February 22, 2008 The zones are backwards too. In Japan, they drive on the right. Link to comment Share on other sites More sharing options...
lamw001 Posted February 22, 2008 Share Posted February 22, 2008 It is because that panel is a JDM unit. They only have black finish instead of our silver. Link to comment Share on other sites More sharing options...
whobaru Posted February 22, 2008 Share Posted February 22, 2008 It's no problem for our switch wire to reach the other side, right? Link to comment Share on other sites More sharing options...
lamw001 Posted February 22, 2008 Share Posted February 22, 2008 I've read that it needs to be lengthened. Link to comment Share on other sites More sharing options...
HighlineCA Posted February 22, 2008 Share Posted February 22, 2008 One of our goals with the JDM setup will be correcting the format - hazard will be in the upper right, and temp controls in the right place. Much more details about the whole project will be posted in this forum. Stay tuned! Rch @ HCA Link to comment Share on other sites More sharing options...
Bigkahuna808 Posted February 22, 2008 Share Posted February 22, 2008 ohhh ver intrested in this unit, I may not need to loose my cuby hole Link to comment Share on other sites More sharing options...
whobaru Posted February 22, 2008 Share Posted February 22, 2008 ohhh ver intrested in this unit, I may not need to loose my cuby hole Link to comment Share on other sites More sharing options...
whobaru Posted February 22, 2008 Share Posted February 22, 2008 Are the JDM versions metric? If so, will this be fixed? Link to comment Share on other sites More sharing options...
CA08LGT Posted February 23, 2008 Share Posted February 23, 2008 subscribe Link to comment Share on other sites More sharing options...
eb50 Posted February 23, 2008 Share Posted February 23, 2008 this would be nice. stand up vendor highline who invested hundres of hours doing it with the USDM and now is trying to help us all with a cheaper solution Link to comment Share on other sites More sharing options...
Bonefizz Posted February 23, 2008 Share Posted February 23, 2008 Oh please, please, please....... Link to comment Share on other sites More sharing options...
biz77 Posted February 23, 2008 Share Posted February 23, 2008 You guys do realize that the center stack is not completely symmetrical and cramming this into the dash will likely leave gaps in some spots and be too tight in other spots. By the way, no one has ever thought of this before: http://legacygt.com/forums/showthread.php?t=55347 Here is a picture of the JDM center vent assembly installed into a USDM car. Notice the bottom left corner will not seat into the opening and there is a nice gap on the bottom right. http://i8.photobucket.com/albums/a41/googalash/Car/DSC00989.jpg I realize that this isn't the main center stack you are looking at, but trust me the cars are not symmetrical between RHD and LHD. Even if you get the electronics to work the unit will not fit without custom cosmetic work. Link to comment Share on other sites More sharing options...
whobaru Posted February 23, 2008 Share Posted February 23, 2008 ^^^ Thanks for the warning. Link to comment Share on other sites More sharing options...
Knight705 Posted February 23, 2008 Share Posted February 23, 2008 all about driver position. the dash is slighting arc'ed toward the driver, so it would be safe to assume that dash pieces out reflect this slight arc. Link to comment Share on other sites More sharing options...
Hops Posted February 23, 2008 Share Posted February 23, 2008 Damnit. I want a new head unit! Buy my cars! Link to comment Share on other sites More sharing options...
