3.0r5eat 0-60mph
Posted
I have the 07' 3.0r in the Dominican Republic. I've read it does 8.2 seconds is that true? feels faster and ive seen videos in youtube o guys doing times under seven secs
  • 2 weeks later...
Posted
hi welcome to bords
And yes it feels faster than 8.2 and I have the proof of it
On my G-TECH-PRO-ss (gadget to measure performance)
I managed to a 0-60 runs and the results were:
1- 8.9 my first a tempt
2- 8.4
3- 8.2 the official time
4- After 5000 k 8.0
5- After 1000 k 7.9
6- 7.89
7- 7.78
8- After 15000 k 7.6
The entire above are done from sea level height of 1200 feet
Then now I live in a region were sea level is 53 feet
So I re run all my test a gained this time with a new lunched technice and got the flowing:
1- 7.2
2- 7.5
3- 6.3 What????? I was surprised the lunch was perfect
So her u go and if u want the pics to prove it will do just ask
Saurus3009
Posted
hi welcome to bords
2- 8.4
4- After 5000 k 8.0
5- After 1000 k 7.9
6- 7.89
7- 7.78
1- 7.2
2- 7.5
Saurus3009
Nice times, just keep in mind that a Gtech wont give 100% accurate numbers, especially if it is not calibrated/placed correctly.
0-60 times are usually more off than the 1/4 miles times (usually off by a few tenths) and MPH (usually quite a bit off track speeds) are, but it should give you a good indication.
I would say that if 99% of your runs are ~7-8 seconds, a low 6 second 0-60 is prob not accurate. It would seem about right for an AT 3.0r to be in the 7s 0-60
Posted
Your 100% correct about off time
On a web site that the GTECH_SS cane be 0.2-0.3 more in the ¼ mile run
and need to subtract it to get corrected times
And since were talking about the ¼ mile hers the result:
1- 16.34 @ 87
2- 16.23 @ 85
3- 16.04 @ 85
4- 15.98 @ 89
5- 15.78 @ 89
6- 15.65 @ 91
7- 15.2 @ 93
And the 60 feet reaction time was all net 2.45-2.58 so have to reduce the 60 feet to gaine good times
Posted
Ive heard the Gtech actually gets you quicker numbers than the track by a little bit not the other way around.
Still a good tool though
Posted
tody i did another run and the numbers was :
0-60 in 7.1
1/4 mile in 15,54 @ 89 MPH
i did 5 run
the same number
by the way it was on a 33 degres day
i think this is the stock numbers
