DougD Posted February 17, 2008 Posted February 17, 2008 I have just purchased a demo 2007 Legacy 2.5i wagon with the touring package and 18,000 km. I have not been able to find out much about the long term reliability of Subarus. Given the kms I would put on the car, the best option for me would be a 6 year, 140,000 Km warranty for about $1,600 with a $100 deductable. Roughly speaking, that is paying about $550 for each of the three years the extended warranty would be in place. In reviewing the maintenance records of previous cars (two camry wagons and a Mecury Villager, all of which had more than 10 years of service) I can only find two items that would have qualified as a warranty repair under an extended warranty, so from that experience, the extended warranty would not be worth it. The only fly in the ointment is the expected reliability of Subarus. I would expect to keep the car 8-10 years, accumulating 25,000 km annually. I live in Eastern Ontario and am therefore exposed to winter driving and salt ladened roads. How can I expect my Subaru to stand up and what has been the membership experience with long term reliability? Thanks Doug
dabbdc Posted February 26, 2010 Posted February 26, 2010 Doug, it is hard to get accurate info on Subaru Warranty pricing - in the US the Certification warranty extends coverage for 6 years and 100k miles from in service date, for you that would be from 2006, that gets you to 2012. We are offered 0,$50 and $100 deductibles for two versions, Classic and Gold. In Classic - Murphy's Law, it won't be covered if it happens to you so get the Gold. If you are keeping the car that long, change the trans and rear dif fluid at 10k-15k (miles) intervals. Change ALL fluids annually. Change oil at 3000 instead of 3750k miles, use synthetic. Consider the service plan that covers oil changes since typical oil change places don't use the Subaru filter and crush washer. Good luck!
GTTuner Posted February 26, 2010 Posted February 26, 2010 Call Subaru directly, sometimes you can snag a better deal right thru them. Google Subaru warranties, some dealers sell online for a hundred bucks over cost.
dabbdc Posted February 27, 2010 Posted February 27, 2010 Subaru Added Security Gold Plus Plan The Gold Plus Plans have been designed to take your Added Security coverage to the next level. Like the Classic Plans, the Gold Plus Plans feature important benefits like: Covers wear and tear on covered partsProtects your Subaru investmentInflation hedge on future repair costs$150 car rental allowanceTransferableCancelableIncludes parts and laborNationwide coverageUnlimited claimsZero deductible option available But Gold Plus also provides a $100 towing allowance and a toll-free emergency phone number. Added Security Gold Plus enhances the Subaru limited warranty by providing immediate benefits that are not covered by your new car warranty. Some of these are: Trip Interruption Allowance If your Subaru must be kept in the shop overnight for a covered repair during or after the warranty period, Added Security Gold Plus pays up to $500 towards your actual expenses for lodging and meals for you and your family when the breakdown occurs more than 50 miles from your home.If necessary, we can even assist you in locating a nearby hotel, rental car or travel agency.Roadside Assistance* "Sign and Drive" service up to $100 per disablement to get you back on the road as quickly as possible with no cash outlay.Emergency dispatched towing for covered warranty or Added Security breakdowns.Emergency on-site road service for jump start, gasoline delivery, tire change (with your good spare) and other minor repairs.Emergency lockout or locksmith serviceComputerized trip routingLost key retrieval system, and much more!Road Hazard Protection Guards you against the costs related to tire damage from potholes, nails, glass and other road hazards not covered by the tire manufacturer's warranty. The four original tires are covered for the repairable leaks or punctures during the plan term (not to exceed 50,000 miles). In the event that tire replacement is necessary, the plan will cover the prorated cost up to $200 based on remaining tire tread depth.Subaru Dealer Locator Service Provides the location and phone number of the nearest Subaru dealer when you travel.Added Security Owner Assistance Toll-free emergency number available 24 hours a day, 365 days a year. Added Security Gold Plus covers so many parts and accessories that they couldn't possibly all be listed here! The coverage includes the components covered by the Classic Plans such as: Engine Engine block, cylinder heads, all internal lubricated parts, camshaft drive belts, intake manifold, flywheel, valve covers, oil sending unit, oil pan, oil pump, motor mounts, seals and gaskets, turbo charger assembly and fuel injection system. Transmission Transaxle case, all internal parts, torque converter, transmission mounts, seals and gaskets. All-Wheel Drive Final drive housing/rear differential assembly, all internal parts, axle shafts, constant velocity joints and boots, double offset joints, propeller shaft, center support bearings, universal joints, wheel bearings and spindle, rear torsion bars and control arms, hub bearings, seals and gaskets. Front Suspension MacPherson struts, transverse links/control arms, shafts and bushings, ball joints, steering knuckles, wheel bearings, stabilizer bar and bushings, seals and gaskets. Brakes Master cylinder, power brake assist unit, anti-lock braking system, traction control system, wheel cylinders, hydraulic lines and fittings, disc brake calipers, seals and gaskets. Steering Steering rack assembly, all internal parts, steering column shaft and coupling, universal joints, power steering pump, seals and gaskets. Cooling and Fuel Radiator, heater core, engine fans and fan motors, water pump, lines, tank, and sending unit. Electrical Alternator, voltage regulator, ignition coil, starter motor and solenoid, wiring harnesses, engine management control unit, power door locks, sunroof motor, power window motors and regulators, power mirror motors, windshield wiper motors, heater blower motor and switch, electric instrument display, trip computer, clock, analog dash gauges, speedometer head, horns, electrical relays and manually operated switches. Air Conditioning Compressor, clutch and pulley, receiver/dryer, condenser, evaporator, expansion valve (orifice), blower motor and compressor seal (factory installed.) Towing and Rental Car If you need a tow due to a covered failure, Added Security pays up to $50 per occurrence. If your car is kept in the shop overnight for a covered failure, Added Security pays up to $30 per day toward a rental car, to a maximum of $200 for each disablement. In addition to those, Added Security Gold Plus also covers items such as: Power antennaCruise controlRadio and speakersCassette deckSeat belt assemblyRear window defoggerThermostatSpringsSteering wheelEngine brackets (including power steering)Gear shift leversHand brake leversPedalsCables and latchesLocksSeat releasesHeater and A/C ducts and ventsWiper armsWindow tracks, guides and handlesFrame, floor boards and body jointsO2 and Knock sensorsCD playerPower seat motorsNavigational systemDVD playerSUBARU Added Security gold plus Pricing Please use this secure form to purchase your desired warranty. You will be contacted within one business day to verify your order and arrange delivery of your Added Security documents. Eligibility: Newplans up to 3/36,000 from in-service date. For all 70k, 80k, 100k plans, add: STI surcharge $495, 6 Cyl Surcharge $95, all other Turbo Surcharge $295 Gold Plus Plan Pricing Your Cost Plan Terms Suggested Retail $100 Deductible 385.00 3/45,000 570.00 527.00 4/60,000 754.00 614.00 5/60,000 928.00 741.00 6/60,000 1,082.00 1,020.00 6/80,000 1,440.00 1,020.00 7/70,000 1,440.00 1,249.00 5/100,000 1,758.00 1,376.00 6/100,000 1,952.00 1,555.00 7/100,000 2,210.00 $50 Deductible 436.00 3/45,000 672.00 613.00 4/60,000 876.00 690.00 5/60,000 1,030.00 777.00 6/60,000 1,154.00 1,107.00 6/80,000 1,614.00 1,107.00 7/70,000 1,614.00 1,402.00 5/100,000 2,004.00 1,479.00 6/100,000 2,158.00 1,707.00 7/100,000 2,414.00 $0 Deductible 563.00 3/45,000 826.00 715.00 4/60,000 1,030.00 767.00 5/60,000 1,134.00 919.00 6/60,000 1,338.00 1,265.00 6/80,000 1,830.00 1,265.00 7/70,000 1,830.00 1,525.00 5/100,000 2,250.00 1,617.00 6/100,000 2,434.00 1,866.00 7/100,000 2,732.00 *Roadside Assistance services are provided by Cross Country Motor Club, Inc., Boston, MA, except in Alaska, California, Oregon, Wisconsin and Wyoming where services are provided by Cross Country Motor Club of California, Inc., Boston, MA The coverages and exclusions stated on this Web site are brief summaries only, subject to revision without notice. Refer to the contract for complete details. Some restrictions and limitations apply. Consult your Subaru dealer for complete details and eligibility requirements.
dabbdc Posted February 27, 2010 Posted February 27, 2010 Dealer Suggested Retail Pricing Schedule Plan TermsClassicGold Plus$100 DEDUCTIBLE3 years / 45,000 miles$246$3604 years / 60,000 miles$238$5445 years / 60,000 miles$442$7186 years / 60,000 miles$564$8726 years / 80,000 miles$840$1,2307 years / 70,000 miles$840$1,2305 years / 100,000 miles$1,230$1,5386 years / 100,000 miles$1,282$1,7427 years / 100,000 miles$1,486$2,000$50 DEDUCTIBLE3 years / 45,000 miles$308$4624 years / 60,000 miles$410$6665 years / 60,000 miles$514$8206 years / 60,000 miles$718$9446 years / 80,000 miles$1,026$1,4047 years / 70,000 miles$1,026$1,4045 years / 100,000 miles$1,436$1,7646 years / 100,000 miles$1,538$1,9487 years / 100,000 miles$1,742$2,204$0 DEDUCTIBLE3 years / 45,000 miles$462$6164 years / 60,000 miles$564$8205 years / 60,000 miles$666$9246 years / 60,000 miles$820$1,1286 years / 80,000 miles$1,230$1,6207 years / 70,000 miles$1,230$1,6205 years / 100,000 miles$1,640$2,0406 years / 100,000 miles$1,846$2,2247 years / 100,000 miles$2,050$2,522 Eligibility: New plans - up to 3/36,000 from in-service date See your dealer for surcharge information (for STI and turbo vehicles). The Subaru Maintenance Plan 7,500 Mile Intervals3,750 Mile IntervalsSevere 3,750 Mile Intervals2 years / 24,000 miles$400$500$8502 years / 30,000 miles$880$1,050$1,8003 years / 36,000 miles$900$1,100$1,8403 years / 45,000 miles$1,100$1,320$2,410 Eligibility: maintenance plans available up to 7,500 odometer miles registered on the vehicle's odometer.
dabbdc Posted February 27, 2010 Posted February 27, 2010 There are a few dealers advertising discounted prices who disclose the retail price - deal with them
ghdtpdna Posted October 18, 2010 Posted October 18, 2010 so does this mean you can get extended one on a car that does not have a warranty right now? For ex, If I buy a 2005 LGT with 60k mile, can I add the ext warranty?
Leonardo Posted March 10, 2011 Posted March 10, 2011 Mine is in for service for engine related and the thing they do is not cover the teardown to find the pint of failure which I have to authorize. Don't have to pay it if the part is covered (which I think is a piston skirt due to them leaving the fuel pressure regulator vacuum hose off.)
