K&N Filter Cleaning Solution & Duration
SpecBee
Posted
Documentation states to clean every 50K miles but it looks like it needs it now. Any thoughts on using windex or a degreasing cleaner & water vs the recommended expensive cleaner? Silicone spray for the oil? Anyone here with experience?
Posted
I've had mine in for 12k+ miles, never cleaned it, hasn't needed it yet. But I would suggest just dropping by autozone and picking up the "re-charging" kit for $10.
Posted
only use the recharge kit because you need to reoil the filter after you clean it. Do not over oil it! just run a thin bead of oil alonog the top pleat and let it work it's way down. let it sit for awile and touch up the parts that are still white.
Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com
Posted
I do mine about every year. just because.
