mattymurn Posted February 6, 2008 Share Posted February 6, 2008 Hi, I am new here, I did a search and could not find anything. A few days ago my dashboard lights went out, not only that but the rear lights went out as well... brake lights work. I checked the fuses (under the dash) and everything is fine. Not sure where to look next, not sure if something could have happened to the control on the steering column as it controls the dash lights and the running lights... thanks matthew Link to comment Share on other sites More sharing options...
icrackedcorn Posted February 7, 2008 Share Posted February 7, 2008 didja check the other fuses? obedience to church and state is subjugation to the unjust authority of men Link to comment Share on other sites More sharing options...
mattymurn Posted February 7, 2008 Author Share Posted February 7, 2008 hmmmm. nope... I imagine, by other fuses you mean the ones in the engine compartment... I did not, but will now.. (I am not really that familiar with Subaru electrics...everything has worked no problems for the past 10 years except for the center console lights which we all know about) thanks Link to comment Share on other sites More sharing options...
Nohenns Posted June 22, 2018 Share Posted June 22, 2018 What happened? Im having the exact same problem, checked all my fuses and they're fine, also the parking light switch doesn't turn on my parking lights so that's my main suspect Link to comment Share on other sites More sharing options...
