Infamous1 Posted February 5, 2008 Posted February 5, 2008 You have a few parameters that aren't needed like the fuel pump , fuel injector?, vehicle speed, EGT, one of the MRP's, also IAT can be checked before the run. The unneeded parameters are sampling the ECU slower. You are getting full advance and no timing pull although maybe a little high. Also you should try starting your log at 2000K rpms, by 2700 I am already at full boost (18psi).
