Does the E-brake disengage the center diff in a 4EAT?
GTS Jeff
Posted
I have an 05 2.5i 4EAT. Driving around, it understeers like a pig. In wider corners, I can set up some oversteer with weight transfer, but I find that the only way to make the car tuck into a tighter corner is with a quick jab at the e-brake.
Now I know traditionally locking the rears on an LSD center diff is not a good idea, but since the 4EAT's center diff is computer controlled clutches, I'm wondering if it knows to disengage with e-brake use. I know the STI does this and there's no reason why the 4EAT couldn't...but I want to be sure.
Posted
That was enlightening. Do you have anything to support that? Because it really doesn't make sense for it to not have that feature. It's a computer controlled electromagnetic clutch system and the computer is already varying the lock constantly...
Posted
Hmmm...what does the diff when the car is coasting then? Cuz the only time I'd use the ebrake is when I'm off the gas. If it's unlocked when off throttle, it might be ok...
  • 10 months later...
Posted
ok i was reading through what the computer does for the 5 eat ..
in 5th gear the diff is open
the pressure is varing depending on throttle position
also steering angle input
and also slip input
my car 4 wheels jacked up ..
in drive wheels spin to 20 mph .. i yank the hand break and all 4 wheels stoped together.
but i can hand break corners .. and i'm sure if your hand break is adjusted properly i think you can too ..
Now that's thinking out of the boxer!:lol:
fyi all 05 + legacy's have built in code reader
