The Frustrations of Altitude
mwiener2
Posted
Stage 2 at sea level (50 degrees in shop)
http://i13.photobucket.com/albums/a257/mwiener2/IMG_0087.jpg
Stage 2+ at sea level (90+ degrees in shop)
http://i13.photobucket.com/albums/a257/mwiener2/mikewhptq.jpg
Stage 2+ at 5500 feet
http://i13.photobucket.com/albums/a257/mwiener2/scan0001.jpg
Stage 3 at 5500 feet
http://i13.photobucket.com/albums/a257/mwiener2/DiscoPotatoDyno.jpg
(Updated 8/22/17)
2005 Outback FMT
Running on Electrons
Posted
I look at altitude as an advantage as oppose to a handicap.
It's all relative, with a FI engine I have an advantage over NA engined cars at altitude and no worst than other FI cars. So it really doesn't matter how much more whp I could make at sea level.
Posted
Exactly! Our losses are what... 4-6% less than NA cars? So on a 300HP crank HP we have a 15HP advantage over a similarly powered non-turbo. Sweet. I want more altitude.
My '05 LGT
My '07 Supercharged Shelby
Posted
I read a Car & Driver article about altitude vs HP. It stated that NA cars lose about 3.3% of their HP for every 1000ft above sea-level you go.
So at 5.280 x 3.3% would mean that an NA car is down almost 18% on their HP vs a FI car. The article also stated that the effects on a FI car are "neglible" in comparison.
Those hits you take on your dyno results look to be considerabley more than what I wopuld call "neglible"! Still lookin like more than enough to me though! lol
Posted
On a stock car, the effects are neglible. Lets say the stock turbo can boost to 16psi without turning into a flame thrower. Stock boost target is 13psi (for example).
At sea level, it hits 13psi no problem. Up here we have ~2 psi less atmosphere. since the turbo can boost to 3psi past it's target, the 2psi loss in atmosphere is made up for by added boost from the turbo. Once you completely leave the efficency range of the turbo (stage 2) the car starts to loose power at altitude.
(Way overly simplified example)
(Updated 8/22/17)
2005 Outback FMT
Posted
If you have less fuel, and less air you have less power. But it takes x amount of hp to go a certain speed. So how does that work out. If you have less power at a given rpm, you would need to run @ a higher rpm to maintain say 70mph.
Posted
A school bus needs something like 15hp to drive 55mph
Thinner air at higher altitude is easier to push out of the way too
(Updated 8/22/17)
2005 Outback FMT
Posted
Nope, your rpm is fixed to speed by the gear ratio. You can't change that on the fly. What the ECU could do is increase the engine load to make more hp even though you are still at the same rpm.
Posted
except, as I was pointing out, unless you're going 100+ mph, there is more than enough power in our engines WITHOUT the turbo to maintain highway speeds.
(Updated 8/22/17)
2005 Outback FMT
Posted
Agreed, bad way of putting what I wanted to get across. You are correct, I should have put load. Been a hectic day, I am painting my calipers on my avalanche.
Posted
:confused: How is that an "except"? Engine load is engine load, regardless of how many hp you need. I didn't say anything about the turbo. It's part of engine load equation but increasing engine load doesn't mean spooling up the turbo you know. ;)
Posted
Good info! Thanks man...
I love this forum...Any day now I'm gonna get it blocked for abuse by our new web filter from hell though :rolleyes:
