door trim removal
Eric B
Posted
Hi guys, nice forum you got here. Lots of good info.
Anyone know how to remove the trim that runs along the bottom of the front door opening(The piece that holds the carpet down)? This is a '97 Legacy GT. My carpet has gottem wet from recent, heavy rain here in Northern California.
Thanks in advance.
Eric
Posted
There is 1 plastic rivet, on the side, towards the front. Along the bottom, I can see some sort of attaching mechanism under the plastic, if I pry it up a bit. It looks.....uh....not round (oval shaped?), so I wonder if it needs to slide back, then up. Prying gently does not seem to work. I will get a repair manual & check in there.
