Kuchar569 Posted November 19, 2007 Share Posted November 19, 2007 I planned to change the front and real differential fluid this weekend in my 2005 Gt 5EAT. Before I pulled the drain plug for the front I figured I better make sure I could pull the dipstick out. Good thing I did because this thing will not come out. It will spin freely in the hole but will not come out no matter how hard I pull on it. I am at a loss for why this is. Anyone have some advice? Thanks. Link to comment Share on other sites More sharing options...
Kuchar569 Posted November 30, 2007 Author Share Posted November 30, 2007 Looks like I'm the only guy with this problem I guess. I'm going to try some vice grips on it this weekend. Link to comment Share on other sites More sharing options...
FocuS Posted November 30, 2007 Share Posted November 30, 2007 My Front diff. stick is VERY tight too... It will come out but for some reason has to oriented an exact way, like it's keyed or something. Try getting it parallel to the firewall and wiggling it back and forth while pulling...this usually works for me. my .02... Link to comment Share on other sites More sharing options...
19Outback95 Posted November 30, 2007 Share Posted November 30, 2007 damn guess i need a new o-ring mines suoer easy to get out. maybe ill just get a good tight dipstick at the junkyard next time i go. Link to comment Share on other sites More sharing options...
spect2k Posted January 21, 2008 Share Posted January 21, 2008 did you end up getting it? Where is it located anyway? Under the cover? Link to comment Share on other sites More sharing options...
bluesuby Posted January 21, 2008 Share Posted January 21, 2008 It's under the cover, passenger side. There's a marking on the cover right above the stick. Link to comment Share on other sites More sharing options...
jhp240 Posted November 2, 2015 Share Posted November 2, 2015 I'm having the same problem. The front diff dip stick is stuck and won't come out, in fact broke the handle trying to pull it out. Will the spout screw out? Help!!! Link to comment Share on other sites More sharing options...
jhp240 Posted November 3, 2015 Share Posted November 3, 2015 Seems like nothing works, the plastic must be melted inside the spout. Anyone know if the spout will screw out? Link to comment Share on other sites More sharing options...
orndog Posted November 3, 2015 Share Posted November 3, 2015 Is there a clip keeping it in? I don't remember anymore from my old 5MT. Link to comment Share on other sites More sharing options...
jhp240 Posted November 3, 2015 Share Posted November 3, 2015 The dipstick tube/spout will come out. Although not threaded, I kept turning the broken dipstick and the tube turned with it. I turned continuously counter clockwise until it came out. After removing it I was able to get the dipstick out by thrusting the stick part down on a solid object while holding it with vise grips. You can't order the tube by itself so be careful. Rust and gunk was the problem. Relieved!!! Link to comment Share on other sites More sharing options...
DonnyJagaru Posted November 5, 2015 Share Posted November 5, 2015 It sounds like it should've been checked in the past. Link to comment Share on other sites More sharing options...
cantona7 Posted December 16, 2016 Share Posted December 16, 2016 The dipstick tube/spout will come out. Although not threaded, I kept turning the broken dipstick and the tube turned with it. I turned continuously counter clockwise until it came out. After removing it I was able to get the dipstick out by thrusting the stick part down on a solid object while holding it with vise grips. You can't order the tube by itself so be careful. Rust and gunk was the problem. Relieved!!! I have run into the same problem changing my diff fluid. I knew it was going to be an issue so I already bought a new dipstick. However, I have broken almost all of the plastic off the top of the disptick trying to get it out. jhp240 - You said that the spout/tube that houses the dipstick isn't threaded, but you were able to removing it by turn it along with the dipstick. If it's not threaded, how did you get the tube/spout back on? Thanks. Link to comment Share on other sites More sharing options...
jhp240 Posted December 17, 2016 Share Posted December 17, 2016 Like I said I was able to spend the entire tube out with the dip stick, and it's not threaded. I clamped the tube with vise grips and started turning being careful not to squeeze it too tight. I put the tube back in with a rubber mallet. Worked! Link to comment Share on other sites More sharing options...
Bradleyeschmidt Posted February 23, 2019 Share Posted February 23, 2019 I used the jack handle from the trunk and got it to twist loose. Heres the video link; Link to comment Share on other sites More sharing options...
hallowground Posted April 8, 2019 Share Posted April 8, 2019 I just did mine for the first time on my own (I never did it cause I never had the proper torx or impact guns in case it was stuck. Luckily my brother did and he helped me out doing it. First, the ring on my dipstick was broken. Second, it was disgusting on the outside and inside like they didnt even bother cleaning it when they did the service. Third, the drain bolt 100% took a torq wrench to break the bad boy free and even that took a minute. Fourth, the gear oil smelt burnt and had very small shavings in it. Idk if that was normal. Fifth, it took vicegrips for me to get my dipstick out as well. Also, does anyone have a recommendation on how to clean the buildup from the inside of the dipstick channel? Sent from my SM-G935V using Tapatalk Link to comment Share on other sites More sharing options...
