j255c Posted November 17, 2007 Share Posted November 17, 2007 So in continuation to my other thread found here http://legacygt.com/forums/showthread.php?t=74941, i think the culprit is my flywheel is going. The clutch is also going but still holds time to time, does anyone know what the general symptoms of a flywheel going? My car makes a vibrational chatter sound which is rpm dependent. Only does this on deceleration or when the clutch is pressed in. Thanks, Jeff 06 TB EVO IX SE stock turbo monster subaru hater Link to comment Share on other sites More sharing options...
PhilT Posted November 17, 2007 Share Posted November 17, 2007 If you are going to change the clutch, always swap the flywheel at the same time, then you know everything is good. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
j255c Posted November 18, 2007 Author Share Posted November 18, 2007 thats what im gonna do. Just going to have to bite the bullet on this one and swap out the whole assembly. 06 TB EVO IX SE stock turbo monster subaru hater Link to comment Share on other sites More sharing options...
Mr. Ed Posted November 18, 2007 Share Posted November 18, 2007 did you try the low rpm thing i was talking about? Link to comment Share on other sites More sharing options...
j255c Posted November 18, 2007 Author Share Posted November 18, 2007 yeah it does it all the time now accept when im accelerating. Clutch out in neutral, clutch engaged decel everything. 06 TB EVO IX SE stock turbo monster subaru hater Link to comment Share on other sites More sharing options...
Mr. Ed Posted November 20, 2007 Share Posted November 20, 2007 If you are going to change the clutch, always swap the flywheel at the same time, then you know everything is good. +1..... if you already know the clutch is near gone/going.... you need to replace both. it's odd that it is doing it in neutral tho..... sounds like it is a combination of three key items that need to be replaced.... clutch, fly, and throw out bearing.... i'd have them check the fork thingy too.... i think mine was bent Link to comment Share on other sites More sharing options...
Legacy05 Posted November 20, 2007 Share Posted November 20, 2007 On my car, I noticed a little shudder .... which I didn't know was flywheel related .. but when I had my clutch changed out due to a bad throw-out bearing my tuner told me my flywheel was borked. Link to comment Share on other sites More sharing options...
j255c Posted November 20, 2007 Author Share Posted November 20, 2007 any detrimental effects that can happen for driving it a couple hundred miles w/ this? 06 TB EVO IX SE stock turbo monster subaru hater Link to comment Share on other sites More sharing options...
Mr. Ed Posted November 21, 2007 Share Posted November 21, 2007 any detrimental effects that can happen for driving it a couple hundred miles w/ this? i drove mine for nearly 2k...... it was extremely scary....if i needed the car to go, and go quick, it wouldn't because the clutch would slipover 3000rpms..... i had to stay off freeways and drive extremely deffensively...... I'd say...out of the 2000 miles, I had to negotiate out of about 5 situations that could have turned out badly.. that being said...after the fifth incident...I parked the car till I could change out the clutch and flywheel..... if your clutch is slipping badly in key gears and you are going to drive it, your putting yourself in a position that you could be looking at much worse than just a clutch repair.... Link to comment Share on other sites More sharing options...
deimos Posted November 21, 2007 Share Posted November 21, 2007 i drove mine for nearly 2k...... it was extremely scary....if i needed the car to go, and go quick, it wouldn't because the clutch would slipover 3000rpms..... i had to stay off freeways and drive extremely deffensively...... I'd say...out of the 2000 miles, I had to negotiate out of about 5 situations that could have turned out badly.. that being said...after the fifth incident...I parked the car till I could change out the clutch and flywheel..... if your clutch is slipping badly in key gears and you are going to drive it, your putting yourself in a position that you could be looking at much worse than just a clutch repair.... +10 when you cant get the power down on the highway when you need, its time to get it changed, mack trucks > legacy gt Link to comment Share on other sites More sharing options...
