Mach V Dan's mega suspension guide
Mach V Dan
OK, conceptually. What limits the amount of drop you can get away with and still maintain a good amount of travel? I hear all the time about lowering and the geometry issues associated with this but nobody explains technically what happens or any solutions to the problem. What kind of parts would maintain adequate geometry while allowing for a good amount of travel at a lower ride height? Or is this not possible?
I'd love to know the nitty gritty to satisfy my own mind.
  • Replies 100
  • Created
  • Last Reply
Top Posters In This Topic
These are two exactly counteracting things -- the more drop you have, the less suspension travel you have, unless you physically relocate the suspensioin mounting points. Even if you did that, you'd soon have clearance issues with the tires anyway.
There ARE some parts to try to correct some of the geometry problems -- Zero Sports has roll center adjusters to try to level out the front control arms, and I think Syms also has a tie rod version of the same thing. But neither of these addresses the loss of travel. Shorter travel means you MUST put stiffer springs and (ideally) dampers on to keep the car from bottming out. Stiffer suspension means less ride comfort, and less bump compliance.
Any lowering spring that claims to maintain as much ride comfort as stock is going to be prone to bottoming out.
So there you go...it's the same old answer: There's no free lunch. Everything is a compromise.
--Dan
Mach V
FastWRX.com
  • 4 weeks later...
For what it's worth, both springs AND dampers impart force on a moving mass (the car). With springs, force is proportional to deflection. With dampers, force is proportional to velocity. Spring-mass systems are oscillators. Increasing spring stiffness (or reducing mass) produces a system of higher frequencies. This generally also means higher suspension velocities, which means you want a higher damping rate to quickly dampen the oscillation. If not, the sucka keeps on bouncing...
There you have my 2 cents...
  • 5 months later...
  • 2 weeks later...
I have to pose this question: Are the springs that come stock on the Bilstein struts on the USDM Spec B very different than those on the LGT? It would seem that they should be. I am interested in lowering my car, but not at the expense of reasonable ride comfort. I was under the impression that Pinks were designed for this very purpose.
  • 6 months later...
I definitely want to upgrade my suspension. I have read on my car, the best combination appears to be JDM rear sway bar plus Blistein Spec b struts and Japan STI Pink springs. I am guessing this will run me about $1,000. I will be going stage 1 next week, so I really want to get my car handling as solidly as possible for a daily driver.
Good choice, pretty close to what I have. If you get everything new you will be spending more than $1000. Check this out:
http://legacygt.com/forums/showthread.php?t=73818
I picked up my struts and springs including tophats nearly new for about $700. The jdm rsb was about $180 new. It is stiff enough to make a nice difference, but not so much that you need bigger endlinks.
Spend some time searching this forum, the level of info on it is insane... :)
edit: don't know if these are still around, but this is an awesome deal, especially seeing you have the wagon:
http://legacygt.com/forums/showthread.php?t=80863
I have spent hours in the last week reading this forum on suspension and the Cobb AP maps. Funny enough I was washing my car today and using Armorall to wipe the interior down, and an Audi quattro 3.0 wagon pulls up next to mine. A bad ass car you can tell immendiately. The fact that that I can upgrade my car to compete both for power and handling, with less weight of course, made me feel I am going to have to get to that place where I am happy knowing I have some fairly serious capabilities hidden in the benign form factor of my car.
So looking at the first link, and thanks for the information ( I hope I can do the same for a newby one day if I ever know enough), it looks like $969 for the Bilsteins and STI pink springs plus probably another $400 for the sway bars. Obviously I want to profit as much as possible from the experience of people like you.
The funny thing is that I bought my car used about two months ago. It rides really low, so I wonder if the guy before me has lowered it. I will have to measure the height on level ground and comapre to others using the same tires. But the handling does not fell tight when I drive agressively.
You will also need the top hats for the front struts.
If you aren't in a rush, I'd say that you should wait for them to pop up on the classifieds. You save yourself a lot of money that way.
Also, you may want to check with King Of Parts. They are pretty awesome at pricing!
Thanks. I am about to remap to Stage 1 Cobb 91 today. I have read on the boards that the ideal suspension upgrade for my model in Boston is the JDM rear sway bar + Bilstein struts+STI pink springs. I think I will slowly try to buy these.
The rear sway is really easy, took about a half hour. Do your struts and springs at the same time, not piecemeal. You can thank me later. :)
I just went stage 1 tonight.:lol::):lol:. I am impressed. The car handles well as well; I am coming from a Saab 9-3, so stock LGT is a different level suspension. Still, I am curious about a rear sway bar. Rallitek sells three rear sway bars. Is the Japan 20mm rear sway the one for our wagon?
The JDM rear sway is what is stock in Japan, I believe. It is tubular, which is nice because it is light. That was the first mod I did. Still pleased with it. Some folks want more, and go with Cuscos front and rear, very stiff. I have heard Whiteline are also good, and the rear is adjustable. Check out the other threads out there.
Will do. Thanks.
Newbie here, I just bought a 8AC Legacy Sedan i SE MT5 2.5 and am not too concerned about making any major mods, but I do have a concern about the factory anti-sway bars. I was talking to a fellow subie owner (05 sedan 2.5i) who had major problems with wind and tracking of the car. He replaced the factory rear anti-sway bar and mounting links, he said the factory bar was hollow and the mounting links where flimsy at best. My question, is the 08 non-turbo of the same level of componets? If so, then I will be replacing both anti-sway bars and links. I want this car for its relibality more then speed, but I also like a car that can corner well. Thank you for all input, and this forum is great. Lots of good useful information here.
Not sure if sway bars affect performance in wind all that much. Nonetheless, the stock US rear sway is a noodle, and is solid, not hollow. The stock rear sway in Japan (JDM) IS hollow, and is a very good handling improvement, lots of people here have them, myself included. Stock links are fine.
You might want to start off with some good tires and a proper alignment. The stock tires on the GT are pretty bad... Not sure what they give you with the 2.5i.
