fonts Posted November 1, 2007 Share Posted November 1, 2007 So just installed my SpecB specific Kartboy STS, front and rear bushings. The shifting is incredibly stiff - so much that set up just isn't workable. Any suggestions??? I'm guessing that the front bushings may have been overtightened??? Thanks. Link to comment Share on other sites More sharing options...
RaGe Posted November 1, 2007 Share Posted November 1, 2007 well everything that you took off nut wise does not need a heeman tightend. A little snug yes but not overtightend. You might want to go back over everything and recheck it. I have the COBB STS and i have a notchiness but not stiffness. OTM. Sorry I didn't mean to start a war which mainly forum people is all about . Link to comment Share on other sites More sharing options...
chenc544 Posted November 1, 2007 Share Posted November 1, 2007 Any suggestions??? I'm guessing that the front bushings may have been overtightened??? Probably. The torque spec on that nut is only like 11 ft-lbs. Also make sure you have the outside plate on the bushing facing the right way. You might also want to check this nut on the pivot. http://img.photobucket.com/albums/v509/Warwick_5S/STS6.jpg Link to comment Share on other sites More sharing options...
fonts Posted November 1, 2007 Author Share Posted November 1, 2007 Thanks guys. Link to comment Share on other sites More sharing options...
fonts Posted November 1, 2007 Author Share Posted November 1, 2007 Probably. The torque spec on that nut is only like 11 ft-lbs. Also make sure you have the outside plate on the bushing facing the right way. You might also want to check this nut on the pivot. http://img.photobucket.com/albums/v509/Warwick_5S/STS6.jpg Thanks. That was it. Guess a little excited when I closed it all up and made the mistake. Feels incredible now. Link to comment Share on other sites More sharing options...
RaGe Posted November 1, 2007 Share Posted November 1, 2007 I thought that is what you might have done. glad it works for ya. Now go take a corner. OTM. Sorry I didn't mean to start a war which mainly forum people is all about . Link to comment Share on other sites More sharing options...
fonts Posted November 1, 2007 Author Share Posted November 1, 2007 It's great. The entire setup is much cleaner and more responsive. A little bit more noise as well but not necessarily a bad thing. Link to comment Share on other sites More sharing options...
