Restrictor Pill Sizes for Bleed Type Boost Control
mickeyd2005
  • 2 months later...
  • Replies 95
  • Created
  • Last Reply
Top Posters In This Topic
  • 1 month later...
Hmm, so I reused my stock VF-40 restrictor pill on my VF-37 setup and Shamar tells me I need a smaller one since I can't hit my boost targets right now even though I am at max WGDC.
Would the 1 mm pill do?
  • 1 month later...
So I installed a 1.2mm pill today. Only a small change from my stock 1.25, but I picked up some extra boost. I was hitting around 15.6 before; I just hit 16.38 without changing anything else. I could probably come close to 17psi in 4th or 5th gear if I really wanted to.
Now to just slightly adjust my tune for it...
  • 3 months later...
  • 1 year later...
I have a 20g turbo and I am having a hard time making target boost which should be 24-26psi. Right now I am maxing at 20-21.
I have a grimmspeed EBCS and the turbo manufacturer recommended a .060" pill to help hit target boost.
It seems everyone on this site is going smaller.....not larger?
Is he right?
PS - I have a Perrin TMIC & AVO Adjustable Actuator if that is needed to know.
Edited by f85stealth
added PS
Is he right?
Who tuned it? You should be asking them about this. If you weren't tuned, then there's your problem. You have a 3 port EBCS, you shouldn't be using a restrictor pill at all if it was done correctly.
edit: Christ, you're this guy:
http://legacygt.com/forums/showthread.php/excessive-intake-temps-190748.html?t=190748
You need a new tuner.
Edited by iNVAR
By the way, that is NOT to be interpreted as "go ahead and yank out the restrictor pill and do a WOT pull". You should NOT do that without knowing how to mess with your tune, or safely dial in your WGDC and turbo dynamics parameters correctly.
  • 3 weeks later...
I have been tuned. Maybe my tuner didn't know about the restrictor pill so its still in my vehicle?
What does it look like and where exactly is it?
I am having another tuner look at my car tomorrow.
  • 1 year later...
Too late to get any info out of this thread?
I've been trying to figure out if dropping from a 1.25 to a 1.20 in my stock '06 is going to make it go kerblooie. There are 7500 miles on the engine.
I only ever use 93oct super, and I live at and operate the car at 900-1200ft elevation. I never see anything more than 13.4PSI in my logs. Will dropping to the 1.2mm pill correct me for altitude without messing anything up to where a tune would be a necessity?
  • 6 months later...
Is there any noticeable difference between a 1.2 mm and a 1.25 mm. I recently bought an 05 LGT with an ewg run off a Trubost 2 port. I am trying to switch back to the stock iwg and bcs configuration. I have sourced a stock bcs and a 1.2 mm pill from a forum member. I have an AP and would like to be able to flash stage 2 or even return to stock. I do work at a machine shop, so I have the ability to ream the pill, if necessary.
  • 11 months later...
