Wooderson Posted October 26, 2007 Share Posted October 26, 2007 As stated, I will being changing my trans/rear diff fluid to Extra-S very soon here. What are the new sealing washers/anything else I will need? A part number(s) would be great. Link to comment Share on other sites More sharing options...
rao Posted October 26, 2007 Share Posted October 26, 2007 You don't need any new ones The transmission once can be reused and the rear diff is a tapered thread with no washer or gasket Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
Wooderson Posted October 27, 2007 Author Share Posted October 27, 2007 You don't need any new ones The transmission once can be reused and the rear diff is a tapered thread with no washer or gasket Nice, thats what I wanted to hear. Thanks. Link to comment Share on other sites More sharing options...
rony Posted October 27, 2007 Share Posted October 27, 2007 The fun part about the tranny is the T-70 Torx bit you will need to get the plug out.. My Car vBGarage Link to comment Share on other sites More sharing options...
bluesuby Posted October 27, 2007 Share Posted October 27, 2007 You don't need any new ones The transmission once can be reused and the rear diff is a tapered thread with no washer or gasket I recommend some Permatex thread sealant for the rear....at least for the bottom (drain) plug. Link to comment Share on other sites More sharing options...
rao Posted October 27, 2007 Share Posted October 27, 2007 I've done it both with and without thread sealer and no leaks either way. Just think the Audi folks would buy new plugs.... Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
fweasel Posted October 28, 2007 Share Posted October 28, 2007 And some sage advice passed on to my by Rao in his driveway... ensure you can remove the fill plug in the rear diff BEFORE you remove the drain plug. Hilarity may ensue. ignore him, he'll go away. Link to comment Share on other sites More sharing options...
