oliiman Posted October 25, 2007 Share Posted October 25, 2007 i was just wondering if there was anyway to adjust my idle to make it a little higher than what it is now (200rpm) most times wen i first start driving the car its at a staedy 800 but if it runs for a little while it starts to get low it might jus be me but your input would be greatly appreciated Link to comment Share on other sites More sharing options...
qikslvr Posted October 25, 2007 Share Posted October 25, 2007 Have you done any modifications to your car? It should idle at about 750RPMs in neutral/park. If you have an automatic; it will drop some when you put it in gear. It should drop to about 600 in an outo in drive, but 200 is way too low. If the vehicle is stock this might be an issue for the dealership to address. How many miles are on it? Let's kick this pig! Link to comment Share on other sites More sharing options...
laz Posted October 25, 2007 Share Posted October 25, 2007 It may be a good introduction if you said what your car was? X --- Link to comment Share on other sites More sharing options...
laz Posted October 25, 2007 Share Posted October 25, 2007 I have avatars turned off, so I can't see it. It still helps in a post to describe what the car model is. X --- Link to comment Share on other sites More sharing options...
lvethesnow Posted October 25, 2007 Share Posted October 25, 2007 when i start my 5mt its at like 1500 after letting it runn a couple min it drops to 750. or so History does not entrust the care of freedom to the weak or timid People sleep peacefully at night cause rough men stand ready to do violence on there behalf Link to comment Share on other sites More sharing options...
GTTuner Posted October 25, 2007 Share Posted October 25, 2007 I used ECU explorer and I set my idle to 700 rpm. It is under the tool menu where timing can be adjusted also. Link to comment Share on other sites More sharing options...
oliiman Posted October 28, 2007 Author Share Posted October 28, 2007 oh sorry i have an 05 2.5i no real mods except the mufflers Link to comment Share on other sites More sharing options...
