Canon20D Posted September 30, 2007 Share Posted September 30, 2007 Im @ 40K and im not all that sure that the previous owner did the 30K change before I bought it @ 36K. SO I want to change the fluid... I get some resistance sometimes getting into 3rd and 4th, like itll click in but as you let the clutch out you realize (to late) that its not Totally in gear and ends up grinding. IE: missing the gear Happens Much more with spirited shifting, when I'm shifting more on instinct, then on tactile input. Are there any fluids that might make the shifting feel smoother, or is that 90% bushings and STS? (im going to get those but not for a bit) Thanks for input Link to comment Share on other sites More sharing options...
bluesuby Posted September 30, 2007 Share Posted September 30, 2007 Redline NS is recommended for the gearbox. It's very hard to find in South Jersey. You can do better on the internet. Link to comment Share on other sites More sharing options...
praedet Posted October 1, 2007 Share Posted October 1, 2007 Go for the Subaru synthetic... Here's the thread Link to comment Share on other sites More sharing options...
Canon20D Posted October 1, 2007 Author Share Posted October 1, 2007 Ill see if Subaru of Cherry hill has it. If I can get quarts of it, and not buy a 20L barrel Link to comment Share on other sites More sharing options...
BlackHole Posted October 1, 2007 Share Posted October 1, 2007 I'm using Uncle Scotty's cocktail and it is working nicely (see Nasioc) since I couldn't justify picking up the 20L of Subaru Extra-S oil. Kyle "BlackHole" Link to comment Share on other sites More sharing options...
chenc544 Posted October 2, 2007 Share Posted October 2, 2007 If you look at the maintenance schedule it actually doesn't require MT fluid change at 30k. It just says inspect... Either way, it sounds like you could use some sync to help with the shifting. Like praedet says get the Extra-S if you can get the quart size or see if anyone in the area wants to go in on the 20L. Link to comment Share on other sites More sharing options...
gianspi Posted October 2, 2007 Share Posted October 2, 2007 Same grind happened to me. Two weeks later and my clutch was toast. enough zip ties and duct tape will fix anything. Link to comment Share on other sites More sharing options...
mickeyd2005 Posted October 2, 2007 Share Posted October 2, 2007 I just picked up 5 quarts of Extra-S oil from a local nasioc member for $40. Haven't changed it yet, but the guy I bought it from says it's the best. He noticed a smoother shift in his 2004 STi. Link to comment Share on other sites More sharing options...
RangerMan Posted October 3, 2007 Share Posted October 3, 2007 I used Castrol Synthetic for my gearbox and rear diff. Seems to work great. I noticed some improvement in shifting but hard to quantify. Got the T-70 bit from O'Reilly Auto Parts for $7 (they had to order it though) Link to comment Share on other sites More sharing options...
