Stewy612 Posted September 28, 2007 Share Posted September 28, 2007 Hey guys, Well yesterday while trying to limp the car home the pedal finally hit the floor and squeals sounded as my clutch took its last dying breath! I got 62k out of it though! anyways, im gonna upgrade to the ACT street clutch, but i cant seem to find what everyones opinions are on our flywheels...should i get rid of it or is it ok? thanks! -Stewy Link to comment Share on other sites More sharing options...
Legacy05 Posted September 28, 2007 Share Posted September 28, 2007 Are you stock ??? If so, honestly, 62k is great out of a stock clutch, I'd just go stock. Link to comment Share on other sites More sharing options...
Stewy612 Posted September 28, 2007 Author Share Posted September 28, 2007 i know isn't it!!! well this car is tracked and auto x'd a good bit so....i wanted to get something a little less squishy Link to comment Share on other sites More sharing options...
qikslvr Posted September 29, 2007 Share Posted September 29, 2007 It can't really be turned or resurfaced and has to be replaced so you can either order a new stock one, get a standard weight aftermarket one or a lightweight. I just had a Spec Stage2 clutch pack and a Spec LW FW installed this week and so far I love it. I haven't been able to "test" it yet since there is a 500 mile break in period, but I think it's going to be great. Let's kick this pig! Link to comment Share on other sites More sharing options...
HansGT Posted September 29, 2007 Share Posted September 29, 2007 If your getting the ACT clutch then you need will need to use a single mass flywheel...ours is dual mass. The kit is for the '06+ WRX but fits the '05+LGT. You can pick up the ACT flywheel or an OEM '06+ WRX flywheel. Either will work. My vote would be OEM to reduce the risk of chatter from the extremely light ACT flywheel. SPEC has a specific set ups for the LGT which are meant to be used with a dual mass flywheel like our stocker. You can use theirs or a new OEM. With 62K on your car, don't try and salvage your existing one. Get a new one. BTW...ACT combo will run you about $800-850, while the SPEC 2 or 2+ w/Fly will run you $950-1150. .....if you have a Subaru Master Card and are earning Subie Bucks....you could purchase the OEM fly with them...basically "free" Do a search...plenty of reviews. Link to comment Share on other sites More sharing options...
Stewy612 Posted September 29, 2007 Author Share Posted September 29, 2007 cool thanks a lot guys thats the perfect info i needed! -B Stew Link to comment Share on other sites More sharing options...
JOE_1985 Posted September 30, 2007 Share Posted September 30, 2007 wait the factory clutch is shot after 60k thats disapointing that means i only have 20k left till a new one Link to comment Share on other sites More sharing options...
Stewy612 Posted September 30, 2007 Author Share Posted September 30, 2007 i do admit that i've been to the track a couple of times and auto crossed her, but from what i hear i did pretty well -Stewy Link to comment Share on other sites More sharing options...
sgt Posted September 30, 2007 Share Posted September 30, 2007 If the pedal hit the floor and didnt come back, its probably your release bearing. If it didnt slip, the clutch is still good. Link to comment Share on other sites More sharing options...
Stewy612 Posted September 30, 2007 Author Share Posted September 30, 2007 no it was slipping and stuff too... Link to comment Share on other sites More sharing options...
qikslvr Posted October 3, 2007 Share Posted October 3, 2007 wait the factory clutch is shot after 60k thats disapointing that means i only have 20k left till a new one Mine started slipping at just over 36K and was done by 40K. It really depends on how you drive it and what mods you have on the car. You'll know when it going because it will start to slip in the middle of the gear or it won't grab at all when you down shift at high RPMs or try to take off fast. Let's kick this pig! Link to comment Share on other sites More sharing options...
Stewy612 Posted October 3, 2007 Author Share Posted October 3, 2007 am i gonna need to replace the throw out bearing and pilot bearing? Link to comment Share on other sites More sharing options...
bobo69 Posted October 3, 2007 Share Posted October 3, 2007 might as well if you have it all apart, cheap insurance Link to comment Share on other sites More sharing options...
Stewy612 Posted October 3, 2007 Author Share Posted October 3, 2007 what all bearings should i replace you think? Link to comment Share on other sites More sharing options...
Stewy612 Posted October 4, 2007 Author Share Posted October 4, 2007 bump? Link to comment Share on other sites More sharing options...
Legacy05 Posted October 4, 2007 Share Posted October 4, 2007 You need to have the throw-out bearing replaced, pilot bearing, and the clutch disc and pressure plate .. just get the kit from King of Parts if you are going stock ... fyi, there is a chance you might need a new flywheel too .. I did. Link to comment Share on other sites More sharing options...
JOE_1985 Posted October 4, 2007 Share Posted October 4, 2007 i hate dual mass flywheels im going to a solid one whenever i have to do the clutch on mine Link to comment Share on other sites More sharing options...
bobo69 Posted October 7, 2007 Share Posted October 7, 2007 i hate dual mass flywheels im going to a solid one whenever i have to do the clutch on mine amen to that! Link to comment Share on other sites More sharing options...
JOE_1985 Posted October 7, 2007 Share Posted October 7, 2007 i know of no one that has had longevity out of those things at all, hope u dont tow or haul much either, hell my factory regular type hyundai clutch still grabbed great at over 100k Link to comment Share on other sites More sharing options...
Fletch Posted October 8, 2007 Share Posted October 8, 2007 Unless you are planning on selling the car, why replace the clutch with another stocker that lasts 50k miles +/- ? I was pleased with the Spec stage 3 & LW flywheel I had on another car. Link to comment Share on other sites More sharing options...
Stewy612 Posted October 9, 2007 Author Share Posted October 9, 2007 sooooo....took the transmission down and..... there's a metal piece between the release bearing and the transmission case that exploded...there's metal shavings everywhere....hmmm good thing she's still under warranty! Link to comment Share on other sites More sharing options...
