Alicafster Posted September 15, 2007 Share Posted September 15, 2007 How come Subaru´s auto tranmission is way slower than other brands. The difference between A/T and M/T 0-100 km/h on the 3.0R is about 1,5 sec. Does anyone have an idea? Link to comment Share on other sites More sharing options...
bpc8bpc8 Posted September 15, 2007 Share Posted September 15, 2007 I wonder if it would be any faster in their sport-shifting mode where you can select your gear through the automatic transmission. That seems faster because you can stay in a lower gear, but it might just be my imagination. Link to comment Share on other sites More sharing options...
captainmorgan Posted September 15, 2007 Share Posted September 15, 2007 they don't call it a slushbox for nothing. Its probably the torque converter actually. Link to comment Share on other sites More sharing options...
DMTaylor Posted September 15, 2007 Share Posted September 15, 2007 Most of the time it has to do with the added rotating mass inside the automatic transmission. Some manufacturers detune the power for the automatic transmissions too. In the case with the 300zx turbo, the automatic was actually faster in the 1/4 mile. With an automatic, you're not losing boost between shifts. Dave Link to comment Share on other sites More sharing options...
Alicafster Posted September 15, 2007 Author Share Posted September 15, 2007 Any possibilities to solve this problem? Software etc.? Link to comment Share on other sites More sharing options...
godwhomismike Posted September 15, 2007 Share Posted September 15, 2007 What year do you have? Subaru revised the A/T in the 2008 model year. . Link to comment Share on other sites More sharing options...
Alicafster Posted September 15, 2007 Author Share Posted September 15, 2007 Subaru outback 3.0R 2007 european model Link to comment Share on other sites More sharing options...
Richard B. Posted September 15, 2007 Share Posted September 15, 2007 How come Subaru´s auto tranmission is way slower than other brands. The difference between A/T and M/T 0-100 km/h on the 3.0R is about 1,5 sec. Does anyone have an idea? Gear ratios gear ratios gear ratios. make them the exact same and it wouldn't be different. as others have said as well...no one launches an a/t at 4k+ rpms without a t/c upgrade. do a launch on a m/t exact same rpm as a a/t with exact same ratios and i be you would be surprised. Link to comment Share on other sites More sharing options...
Richard B. Posted September 15, 2007 Share Posted September 15, 2007 Most of the time it has to do with the added rotating mass inside the automatic transmission. Some manufacturers detune the power for the automatic transmissions too. In the case with the 300zx turbo, the automatic was actually faster in the 1/4 mile. With an automatic, you're not losing boost between shifts. Dave same exact thing is happening with the 335i's. people are saying the procede a/t is quicker than the m/t. Link to comment Share on other sites More sharing options...
Alicafster Posted September 15, 2007 Author Share Posted September 15, 2007 So are there methods solving this problem? Hardware/software? Link to comment Share on other sites More sharing options...
Scotty Posted September 15, 2007 Share Posted September 15, 2007 same exact thing is happening with the 335i's. people are saying the procede a/t is quicker than the m/t. 335i with the SMG gearbox would be faster than a manual, and faster than a traditional automatic. The SMG IS a conventional gearbox, well it's a sequential gearbox with a computer controlled hydraulically actuated clutch. It doesn't use a torque converter. Link to comment Share on other sites More sharing options...
godwhomismike Posted September 15, 2007 Share Posted September 15, 2007 335i with the SMG gearbox would be faster than a manual, and faster than a traditional automatic. The SMG IS a conventional gearbox, well it's a sequential gearbox with a computer controlled hydraulically actuated clutch. It doesn't use a torque converter. I disagree, there are some automatic transmissions, which are quicker than a manual. The one hat comes to mind right away is the Porsche 911 Turbo. The turbo-powered Sky and Solstice roadsters are also quicker with the automatic than the manual. . Link to comment Share on other sites More sharing options...
forestir Posted September 15, 2007 Share Posted September 15, 2007 My guess: With a manual, you can rev it up high and dump the clutch. With an automatic, how high and rpm you can do that at is determined by the torque converter stall speed. If stall speed is low, you get a launch similar to a manual revved up only to the same middling rpm--this is like the rolling 5-60 numbers, which are off by at least a second from the abusive (?) high rpm clutch dump. Link to comment Share on other sites More sharing options...
Garandman Posted September 15, 2007 Share Posted September 15, 2007 Gear ratios gear ratios gear ratios./// What he said. Subaru MT's are geared numerically higher, so you have better acceleration and higher highway rpms. At the expense of some noise, wear, and fuel economy. Even the Subaru AT's are geared higher than some other cars. Who Dares Wins スバル Link to comment Share on other sites More sharing options...
Scotty Posted September 15, 2007 Share Posted September 15, 2007 I disagree, there are some automatic transmissions, which are quicker than a manual. The one hat comes to mind right away is the Porsche 911 Turbo. The turbo-powered Sky and Solstice roadsters are also quicker with the automatic than the manual. . Yes, automatics can be faster if they are tuned for that. Unfortunately, most cars are tuned for smoother shifts, which is slower. Head to head, a semi-auto gear box w/computer controlled clutch will be faster than a tuned automatic w/torque converter. The fastest will still be a Zero-shift gearbox and equivalents which engages the next gear and releases the current gear at the same time. While extremely fast, they can be violent with the shifts. Link to comment Share on other sites More sharing options...
gugarci Posted September 15, 2007 Share Posted September 15, 2007 335i with the SMG gearbox would be faster than a manual, and faster than a traditional automatic. The SMG IS a conventional gearbox, well it's a sequential gearbox with a computer controlled hydraulically actuated clutch. It doesn't use a torque converter. The 335I uses the Steptronic gearbox which is a great fast shifting auto gearbox. The SMG is not used on the 335I's. On that note Subaru needs to introduce a DSG type gearbox. Link to comment Share on other sites More sharing options...
Carter Posted September 15, 2007 Share Posted September 15, 2007 Ill consider trading the LGT when the Evo X DSG comes out... Link to comment Share on other sites More sharing options...
Richard B. Posted September 16, 2007 Share Posted September 16, 2007 Yes, automatics can be faster if they are tuned for that. Unfortunately, most cars are tuned for smoother shifts, which is slower. Head to head, a semi-auto gear box w/computer controlled clutch will be faster than a tuned automatic w/torque converter. The fastest will still be a Zero-shift gearbox and equivalents which engages the next gear and releases the current gear at the same time. While extremely fast, they can be violent with the shifts. im been wondering how mercedes pulls it off. everytime i see a review of their cars in a mag it is always compared to a m/t. funny thing is though, the merc's line never has a zig zag point for shifting. Link to comment Share on other sites More sharing options...
chenc544 Posted September 16, 2007 Share Posted September 16, 2007 Gear ratios gear ratios gear ratios. make them the exact same and it wouldn't be different. as others have said as well...no one launches an a/t at 4k+ rpms without a t/c upgrade. do a launch on a m/t exact same rpm as a a/t with exact same ratios and i be you would be surprised. This is true to certain extend. The dyno has also shown that 5EAT puts down less power than the 5MT. Link to comment Share on other sites More sharing options...
Garandman Posted September 16, 2007 Share Posted September 16, 2007 This is true to certain extend. The dyno has also shown that 5EAT puts down less power than the 5MT. Are those runs posted? Who Dares Wins スバル Link to comment Share on other sites More sharing options...
ArcTec34 Posted September 16, 2007 Share Posted September 16, 2007 yeah they are somewhere. Link to comment Share on other sites More sharing options...
mjp0212 Posted September 16, 2007 Share Posted September 16, 2007 Are those runs posted? they are everywhere, just look at a run with a 5eat(modded or not) and a 5mt(modded or not) and you can easily tell the 5eat is putting down less. stage 2 Link to comment Share on other sites More sharing options...
Euclid Posted September 16, 2007 Share Posted September 16, 2007 It's punishment for buying an auto Link to comment Share on other sites More sharing options...
wukindada Posted September 16, 2007 Share Posted September 16, 2007 They should give me a call......... Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
wukindada Posted September 16, 2007 Share Posted September 16, 2007 Performance only for my call........ I'd answer it on the "brick" cel:) Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
