Bala Posted September 6, 2007 Share Posted September 6, 2007 I am trying to find out what exactly is involved in doing a tranny swap from a 07 Legacy Spec B into 06 WRX. Here are some questions i have: Will I need Legacy's rear Diff? If so, what Diff does the Legacy comes with? Will I have to use a different drive shaft? If so, which one? If i do have to change the rear DIff in order to accomodate the Legacy's tranny, will i have to change the rear axles/hubs and brakes? 6 spd manual, spec.B only 1st 3.636 2nd 2.235 3rd 1.521 4th 1.137 5th 0.891 6th 0.707 final 3.454 The reason I prefere to do the Legacy's Spec B tranny swap over the STI's is because it does not have the DCCD and the tranny itself is cheaper. Please help, any comment welcomed. Thanks. Link to comment Share on other sites More sharing options...
