kevkel33leg05 Posted September 1, 2007 Share Posted September 1, 2007 Question i have a 2005 legacy gt i ordered a SPEC stage 2 plus clutch then i ordered a xact streetlight flyweel i was told they would work together but i put the pressure plate on the flywheel the bolt holes do not line up. Does the Spec clutch only work with the Spec lightweight flywheel or did i maby get a wrong part number? thanks for the help!!! Link to comment Share on other sites More sharing options...
rony Posted September 2, 2007 Share Posted September 2, 2007 I think the SPEC only works with the SPEC, if they don't fit, I think you answered your own question. My Car vBGarage Link to comment Share on other sites More sharing options...
groff Posted September 2, 2007 Share Posted September 2, 2007 you can't combine the ACT and SPEC setups. ACT is not made to work w/ the stock flywheel whereas the SPEC setup was designed to do so. ACT needs its own flywheel. SPEC will work w/ stock or the SPEC flywheel. Link to comment Share on other sites More sharing options...
