Radio, Climate Control, Keyless entry not working!!!
DLy
I thought I was fairly competent at installing stereos, but apparently I'm not. I just finished installing a 4 channel amp using the speaker level inputs from my stock head unit. I cut the white harness from behind the head unit, splicing in the input and output wires to and from the amp. The rest I just spliced back together.
I've been installing stereos off and on for 10 years and I'm usually very good at this stuff, but for some reason I had serious problems when I turned the car on after putting it all together. I have no blown fuses and I have 12V coming out of the yellow/red wire of the harness...but nothing out of the blue/red wire.
Not working is the head unit, climate control, trip/fuel/clock display, and my keyless entry doesn't work. Everything else works just fine! Could it possibly be a relay?
Thank you for your help
I checked them all with a ohmmeter and they had a shorted connection which definitely confused me. I'll look again. Does anyone have a more readable listing of the fuses? The fuse panel has abbreviations that aren't too awful helpful.
Thanks Evo
^if the car is switch on, it should either read 12v +/- 0.9 , IIRC, get a $2 fuse checker from the closest autoparts store, its a lot easier when your down there
Current:MY05 SWP wagon - 253/290 :rolleyes: UP, AEM CAI, Invidia Q300, tuned@yimisport
OLD: MY06 GRP - 274/314 :cool:
Ok, got me a fuse checker. Easier to use than my ohm meter...but same result. I have checked every fuse in the fuse box and in the engine bay with none being blown.
As I said before, I'm getting 12v to the yellow/red wire (12v acc) on my white harness. I'm supposed to be getting 12v for the blue/red wire (12v mem) right?
Does anyone have a schematic from their shop manual? That would help me tremendously. I'm worried it might be a relay, though I wouldn't know where to start.
Also, I noted last night that when I have my parking lights or headlights on (my DRLs are disabled) that I cannot run my brightness all the way up! I can select every setting except the uber bright one. Though when I switch my headlights completely off, it reverts back to the highest brightness.
This is WEIRD.
pull all the fuses and check them ... it honestly sounds like a fuse, i blew one awhile ago installing a gauge(me just being careless) but it happens, my blown fuse still lit up, but it was blown,,pretty weird...whered you tap the remote wire, maybe that wire doesnt like it?
I didn't tap the remote wire. Because I'm using SLI, the signal from the stock HU will turn on the Amp automatically. A remote isn't required. I've already checked the amp and it's getting 12v as necessary though isn't much good without a signal from the HU.
I'll physically check all the fuses now. Thank you for your help on this evo!
It's definitely not a fuse of any kind. I've physically checked all and they're all good. Because I've check the blue/red on my fuel comp display and it's not getting 12v...I have reason to believe that I've popped my RC-5103 relay in the engine compartment. I'm not sure how it happened...but it's the only rational explanation for what's not working.
Can someone please chime in on where I can find an electrical manual or have knowledge about these things? I've been physically tracing that stupid blue/red wire underneath my dash and it's been a serious pain. I would much rather read a book on it!
good night evo... if it were legal in Arkansas...or even remotely possible on a genetic level...I would so have your babies right now.
I am now almost entirely convinced that it's the MainFan2 grey relay in the engine bay that is bad. For two reasons. One, a couple of the vacation pics clearly showed that what was not working were directly related to that relay....and two, because I jumped the hot 12v accessory on the audio harness to the 12v memory (back loading the voltage from the open circuit) and it turned on my clock display! (I know I know, this is a huge electrical nono...but I'm fairly desperate.)
Have you guys heard of someone blowing a freaking relay? I was so damned careful and even was proud of the clean install. It must have been a freak occurrence for me to pop the relay like I did. Welp...off to Subaru to order a new one.
  • 2 months later...
  • 2 years later...
Anyone ever find out what caused this? Same thing randomly happened to my car last night. No blown fuses or anything!
[URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard
  • 2 years later...
There is a PDI fuse under the hood that blew in mine. Edited by BAC5.2
  • 9 years later...
