kcarter116 Posted August 1, 2007 Share Posted August 1, 2007 About half of the time I go to put my 08 LGT into reverse, it doesn't go - i.e., there is a strong resistance before the shifter pulls all the way back. I usually end up rowing into first and after that about 60% of the time it will slip into reverse fine. Other times I have had gone 1 - 2 - 3 - R or let the car roll fwd or back a little bit by itself. Once or twice I actually put it into 1 and rolled it forward, then into reverse. This isn't caused by the 5 - R lockout feature (I don't park while in 5th). Any thoughts / experiences? I am wondering if I need to call the dealer. Link to comment Share on other sites More sharing options...
BigT Posted August 1, 2007 Share Posted August 1, 2007 Happens all the time. I usually just depress the clutch again. Yeah.... subaru sucks at MTs Link to comment Share on other sites More sharing options...
-TT- Posted August 1, 2007 Share Posted August 1, 2007 ^ +1 (except for the part about subaru MTs sucking) just fully release the clutch, re-clutch, and then grab Reverse as he said. just the way it was made Link to comment Share on other sites More sharing options...
gianspi Posted August 1, 2007 Share Posted August 1, 2007 Yes reverse had no syncros. Get used to it. enough zip ties and duct tape will fix anything. Link to comment Share on other sites More sharing options...
-TT- Posted August 1, 2007 Share Posted August 1, 2007 NVM the no syncho stuff. found the post: http://www.legacygt.com/forums/showpost.php?p=51377&postcount=14 Link to comment Share on other sites More sharing options...
kcarter116 Posted August 1, 2007 Author Share Posted August 1, 2007 I think I'd rather not hear that this is normal. My audi 6sp never had a problem like this. I will try the engage / disengage the clutch tip. Link to comment Share on other sites More sharing options...
qikslvr Posted August 1, 2007 Share Posted August 1, 2007 Another just double clutch it. This is not Subaru specific. It's the same on just about every manual tranny ever made. This is somewhere around my 20th manual tranny car and ALL of them either had to be put in first or double clutched to get into reverse cleanly. As stated below there is no synchro on the reverse gear and the first gear syncro is a good substitute. If this doesn't line it up. Reclutching will get it the rest of the way. Out of those 20 plus stick shift cars this has been one of the better one I've had. Let's kick this pig! Link to comment Share on other sites More sharing options...
gianspi Posted August 1, 2007 Share Posted August 1, 2007 I think I'd rather not hear that this is normal. My audi 6sp never had a problem like this. I will try the engage / disengage the clutch tip. I'm not going to tell you what you want to hear, but rather I'm going to tell you the truth. Reverse has no syncros and it's going to be a bitch to engage some times. Don't start comparing German 6spds to Japanese 5spds because they are obviously completely different machines. enough zip ties and duct tape will fix anything. Link to comment Share on other sites More sharing options...
Bbc84 Posted August 1, 2007 Share Posted August 1, 2007 on my beater 98' 200sx it was the same, I learned stick in that car and I thought the trans was broken. but a friend taught me just put it in first and then go back into reverse, works everytime i cant get into reverse directly. Link to comment Share on other sites More sharing options...
-TT- Posted August 1, 2007 Share Posted August 1, 2007 I think I'd rather not hear Link to comment Share on other sites More sharing options...
diamondgraymetallic21 Posted August 1, 2007 Share Posted August 1, 2007 I've had the same issue with every MT I've owned also, the synchros are set for forward movement, IE 1,2,3,4,5 etc. So to stop them so they will allow you to go into reverse easier, I always just throw it in 1, release the clutch just enough to stop the synchros, then it goes into reverse like butter. Don't quote anything I stated, I don't know exactly what is happening, but I've had it explained before and it makes sense and the fix is simple, instead of ramming the shifter into reverse repeatedly. Link to comment Share on other sites More sharing options...
BigT Posted August 1, 2007 Share Posted August 1, 2007 Audi makes amazing MTs as well. It's really not a fair comparison. Their MTs are especially nice. You may have just been spoiled before. Ours is great, it just sucks now that I've driven an Audi MT. But hey it is strong as hell. Link to comment Share on other sites More sharing options...
Legacy05 Posted August 1, 2007 Share Posted August 1, 2007 doesn't make any sense to me, I have no issues going into reverse at all ... are you sure you are going over all the way??? hmm. Link to comment Share on other sites More sharing options...
dasbigunit Posted August 1, 2007 Share Posted August 1, 2007 I've had the same issue with every MT I've owned also, the synchros are set for forward movement, IE 1,2,3,4,5 etc. So to stop them so they will allow you to go into reverse easier, I always just throw it in 1, release the clutch just enough to stop the synchros, then it goes into reverse like butter. ^+1 Except I let the clutch up all the way in neutral, then go to reverse. Also it's a little harder when it's still in cold idle... Link to comment Share on other sites More sharing options...
qikslvr Posted August 1, 2007 Share Posted August 1, 2007 Some people just the magic touch. I can manage to get it to slip right in after moving forward, but it's when the car has been parked overnight with the e-brake on that my reverse doesn't always cooperate. It's only after not being able to get it to slip right in that we have to resort to the methods describe in this thread not every time we shift into reverse. Let's kick this pig! Link to comment Share on other sites More sharing options...
kcarter116 Posted August 1, 2007 Author Share Posted August 1, 2007 Thanks for the help and the tips. Of course, it hasn't happened again, but I appreciate the explanation of what's going on - lets my engineer brain visualize it. My Audi was the only other standard car I've had - it's the only basis for comparison I have. I guess I was spoiled by my previous ride. Link to comment Share on other sites More sharing options...
TravisS Posted August 1, 2007 Share Posted August 1, 2007 Of course, it hasn't happened again It doesn't, or shouldn't, happen all the time. I put my car in reverse, at a minimum, twice a day. I only have a problem with it maybe once a month. Link to comment Share on other sites More sharing options...
hogmeat Posted August 2, 2007 Share Posted August 2, 2007 I've found that putting it into 4TH, and then R works great, everytime. I just feel something "clunk" into place in 4th, and it falls into R easily. 1,3 make it "clunk" the other way. I'm pleasantly surprised... It was most certainly worth the couple bucks and 10 mins of my time. CLICK HERE FOR THE HOGZAUST Link to comment Share on other sites More sharing options...
c-lo Posted August 2, 2007 Share Posted August 2, 2007 I was always taught to go into first then reverse. Has worked on every manual car I've had. 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
GTTuner Posted August 2, 2007 Share Posted August 2, 2007 I was always taught to go into first then reverse. Has worked on every manual car I've had. Reverse can be a stinker at times. I shift to first then back to reverse and it slips right in gear. This is not the first car I have owned that was difficult to get into reverse. I had a 94 Altima that exhibited the same condition. Link to comment Share on other sites More sharing options...
VXCL Posted August 2, 2007 Share Posted August 2, 2007 double clutch works, but i find a shift to 2nd and 4th then clutch then reverse works better usually MAYHEM #122/22 STS NNJR SCCA AUTOX4U.COM XENON RETRO GUIDE Link to comment Share on other sites More sharing options...
Mr. Ed Posted August 8, 2007 Share Posted August 8, 2007 I think I'd rather not hear that this is normal. My audi 6sp never had a problem like this. I will try the engage / disengage the clutch tip. i can't count the number of my friends that have had vw and audi syncros go bad at low mileage... i love my tranny, even if i got to depress the clutch a second time to get it in reverse.... Link to comment Share on other sites More sharing options...
zildjiank Posted August 8, 2007 Share Posted August 8, 2007 Happens all the time. I usually just depress the clutch again. Yeah.... subaru sucks at MTs Link to comment Share on other sites More sharing options...
