RX300T Posted July 31, 2007 Share Posted July 31, 2007 Hi there, I currently have a 2.0 JDM Legacy GT 5EAT. 2005 yr. I managed to find a good deal on a jdm transmission. Question is, i do not know if it is a spec B trans or just an ordinary one. anyone knows the differences other than the gearing, from the spec B and the normal GT 5EAT? the serial number on the transmission is : TG5C7CBABA-Y5. Can't remember the normal trans number but it's different. Thanks in advance. Link to comment Share on other sites More sharing options...
VTGT Posted July 31, 2007 Share Posted July 31, 2007 care to share where you are getting it and how much? Link to comment Share on other sites More sharing options...
RX300T Posted August 1, 2007 Author Share Posted August 1, 2007 care to share where you are getting it and how much? i'm actually in asia. my mechanic just got a set from japan but specs still unknown as he has no time to check. I was told things that need to be changed with the gearbox is the rear diff which will include an LSD. price-wise not confirmed but should be a top-up of abt 500 including my gearbox if the one i'm getting is a spec B. Link to comment Share on other sites More sharing options...
VTGT Posted August 1, 2007 Share Posted August 1, 2007 thats sweet if the spec b tranny is actually a lot stronger. Link to comment Share on other sites More sharing options...
RX300T Posted August 2, 2007 Author Share Posted August 2, 2007 I'm not too sure if it's even a spec B tho but if i'm not wrong, only the gearing is different. i'm changing it more for the gearing and the LSD. Also the fact that i'll be sending my VB to ipt for the works next week. so hoping i can get an answer before deciding on the swap. Link to comment Share on other sites More sharing options...
REM87O Posted August 2, 2007 Share Posted August 2, 2007 Where is asia are you? I wonder if Paul from AVO would be able to help you out? Link to comment Share on other sites More sharing options...
RX300T Posted August 4, 2007 Author Share Posted August 4, 2007 'm in Singapore. Thanks, will try posting on avo forum. Link to comment Share on other sites More sharing options...
2005garnetGT Posted August 4, 2007 Share Posted August 4, 2007 usdm 5EATs have a rear viscous LSD Link to comment Share on other sites More sharing options...
RX300T Posted August 4, 2007 Author Share Posted August 4, 2007 usdm 5EATs have a rear viscous LSD i'd better find out more info before commiting. thanks. can anyone help with the serial number? any other way to find out if it's a spec B? Link to comment Share on other sites More sharing options...
