mickeyd2005 Posted July 27, 2007 Share Posted July 27, 2007 no tuner fixes it, they don't know what it is. I think FFS is now available on Protunes. Link to comment Share on other sites More sharing options...
2005garnetGT Posted July 27, 2007 Share Posted July 27, 2007 I think FFS is now available on Protunes. sucks for all the OTS map users though Link to comment Share on other sites More sharing options...
Xenonk Posted July 27, 2007 Share Posted July 27, 2007 Happens at the strip and on the street. When I NLS into 4th, the car like, hits a brick wall for a second, then slowly regains it's speed. I still managed a 14.3 at the strip, but it annoys the piss out of me. I dind't have a problem before when I went 14.1, but now I do. It happened once going into 3rd. I have a slight tune by a local person who's flashed my map onto another LGT and he's had no problems whatsoever. Someone please help!!! your synchros are going to hate you. I run 14.3s in my stock powered GT and I do it with just simple smooth and crisp shifting. You seriously shouldnt be FLAT FOOTING it. If you want to do that, call up Andrewtech and get yourself a PPG dogbox tranny instead. btw, what are your 60' times?? On a fairly good day, you should hit 1.8s easy. A good launch is all you need to cut the times down. The stock turbo is small enough where you will hit full boost as long as you keep your rpms above 4000 rpms after each upshift. If anything, you're just maxing out the AFRs and the car is probably pulling timing more than anything (since you have your foot pegged and you're at WOT, causing the car to most likely pull timing and keep the fuel injectors running to keep your car from knocking). You really dont need to ride up to the rev-limiter either, because you are not going any faster (or accelerating any quicker) at that point. Either you raise your rev-limiter or you shift.. I just shift right at redline. So long as your rpms drop back down to no lower than your peak torque rpm while WOT, you should be hauling ass. Keefe Link to comment Share on other sites More sharing options...
frathouse87 Posted July 27, 2007 Share Posted July 27, 2007 Yea, give it a good launch keeping the RPM's in your boost, in my case is around 3000-3500. Shift as close to fuel cut as you can in first gear to get the RPM's up since the biggest jump in gearing is from 1st-2nd, so around 7000-7100. Then shifting the rest right at redline and that is the best you can be shifting. I was going to say if your at redline and your compressing the clutch and keeping the gas on, the only place your going to go is the cutoff? SOunds stupid... Zac Link to comment Share on other sites More sharing options...
Cossey Posted July 28, 2007 Author Share Posted July 28, 2007 Ya, the 14.3 was lifting. My best was a 14.197 w/ a 1.95 60'. I'm going back next Wednesday, lifting, and trying to launch better. I get too ancy and tend to let the clutch out too much rather than ride it out. Thanks for the help though guys! Link to comment Share on other sites More sharing options...
PhilT Posted July 28, 2007 Share Posted July 28, 2007 Phil. Read the entire quote form rao. I deleted that part because I believe it was an example of how to show not to make it happen. OP, NEVER let go of the gas. Sorry, I don't really understand it, but the way I read it was that was how to make it happen, not how to avoid it. If he's not lifting at all, then he's just plain crazy Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
Mr. Ed Posted July 28, 2007 Share Posted July 28, 2007 what all have you done to your car? my best time was a 14.3 @ 97mph last week but the track was horrible...very slick as it had rained all day...and I never make it into 4th. plus my launching sucks i have the problem you are having from 1st to second, then third is great...but I never make it into 4th mods: cobb pulley ap stage 2 sti up kn panel filter straight through exhaust 225 45 tires and the car is lowered slightly i think my belts are slipping a little on the cob pulley, as of late when i go wot i hear a screaching noise from under the hood like i said i beat my old time of 14.7 (juut exhaust and an ap) but still haven't been able to break 100mph, which is my goal. with me, i'm new to racing so i think i will find the answer in my launch. I also notice my clutch slipping badly when heavy on it so I know that is going to be replaced soon. Ya, the 14.3 was lifting. My best was a 14.197 w/ a 1.95 60'. I'm going back next Wednesday, lifting, and trying to launch better. I get too ancy and tend to let the clutch out too much rather than ride it out. Thanks for the help though guys! Link to comment Share on other sites More sharing options...
Cossey Posted July 28, 2007 Author Share Posted July 28, 2007 When I ran the 14.3, I was bone stock. When I went 14.197 @ 96.1, I was just reflashed. I still need to put on my coilovers, which will help with my launching considerably. I also just ordered a new Walbro 255lph pump, and an AEM UEGO WBO2. I'm trying to see what I can do with just reflashing the stock ECU and a little more fuel and boost and timing lol. Link to comment Share on other sites More sharing options...
2005garnetGT Posted July 28, 2007 Share Posted July 28, 2007 what all have you done to your car? my best time was a 14.3 @ 97mph last week but the track was horrible...very slick as it had rained all day...and I never make it into 4th. plus my launching sucks i have the problem you are having from 1st to second, then third is great...but I never make it into 4th mods: cobb pulley ap stage 2 sti up kn panel filter straight through exhaust 225 45 tires and the car is lowered slightly i think my belts are slipping a little on the cob pulley, as of late when i go wot i hear a screaching noise from under the hood like i said i beat my old time of 14.7 (juut exhaust and an ap) but still haven't been able to break 100mph, which is my goal. with me, i'm new to racing so i think i will find the answer in my launch. I also notice my clutch slipping badly when heavy on it so I know that is going to be replaced soon. 5mt or 5eat? I ran a 14.8 on a bone stock 5eat, would have been ~14.6 had I not shortshifted 3rd badly. Link to comment Share on other sites More sharing options...
Mr. Ed Posted July 29, 2007 Share Posted July 29, 2007 5mt Link to comment Share on other sites More sharing options...
mickeyd2005 Posted July 29, 2007 Share Posted July 29, 2007 Yea, we tried raising the boost limit a little bit, but no help. Maybe I didn't raise it high enough? OP, you never told us what happened. Datalogs? Rom? BTW, the threshold value that we are talking about is NOT the boost limit. In Enginuity, look under the Misc category. You will see something called Rev Limit Fuel Resume. The stock value is 9.67 psi. Raise it to 14 psi. Merchgod added this in March 2007 so you need the latest defs. I believe Cobb recently added it to their Protuner as well. Link to comment Share on other sites More sharing options...
johnAWD Posted July 29, 2007 Share Posted July 29, 2007 My only input to this thread is this - lift to shift. Period. Link to comment Share on other sites More sharing options...
mickeyd2005 Posted July 29, 2007 Share Posted July 29, 2007 Oh yeah... I forgot to add that my friend who shifts like this on his EVO 9... well, he learned how to do this on his heavily modified EVOIII (Galant). He left bits and pieces of his EVOIII transmission along the road. Link to comment Share on other sites More sharing options...
Cossey Posted July 29, 2007 Author Share Posted July 29, 2007 I've had no issues doing it in any of my other cars, but I've been lifting lately. I've been using ECUFlash for software, but switching to Enginuity once my WBO2 gets in so I can log that as well. Link to comment Share on other sites More sharing options...
mickeyd2005 Posted July 29, 2007 Share Posted July 29, 2007 That parameter is not in ecuflash so you definitely need to modify it in Enginuity. Link to comment Share on other sites More sharing options...
2005garnetGT Posted July 29, 2007 Share Posted July 29, 2007 Oh yeah... I forgot to add that my friend who shifts like this on his EVO 9... well, he learned how to do this on his heavily modified EVOIII (Galant). He left bits and pieces of his EVOIII transmission along the road. weak point on turbo DSMs/GVR4s is, and has always been, their trans/ Link to comment Share on other sites More sharing options...
frathouse87 Posted July 30, 2007 Share Posted July 30, 2007 +1 Link to comment Share on other sites More sharing options...
Cossey Posted July 30, 2007 Author Share Posted July 30, 2007 Werd. When I had my 1G AWD DSM, I got a Shep tranny for it and loved every second of it. Link to comment Share on other sites More sharing options...
Xenonk Posted July 31, 2007 Share Posted July 31, 2007 Ya, the 14.3 was lifting. My best was a 14.197 w/ a 1.95 60'. I'm going back next Wednesday, lifting, and trying to launch better. I get too ancy and tend to let the clutch out too much rather than ride it out. Thanks for the help though guys! yea, sounds like the launch is what you need to work on, not fast shifting. A good launch should be anywhere from 1.6 to 1.8s for your 60' times.. if you can't get that part correctly, then driving the car hard down the rest of the way is really pointless. You're looking for the perfect launch, but to do that you need to learn how to rally launch it if you dont have a 2-step electronic setup. You need to let the clutch ride out some if you are on the stock pressure plate. There's also the fact that you are dealing with a lot more friction and drivetrain loss in an AWD turbo car, so if you're not making the power and right amount of boost, you're not going anywhere. Keefe Link to comment Share on other sites More sharing options...
frathouse87 Posted July 31, 2007 Share Posted July 31, 2007 correct, the launch is everything. I just did a 2.3 60' for a 13.4 1/4. That's awful launch w a good time, so now I'm anxious to learn to launch better lol Zac Link to comment Share on other sites More sharing options...
