Breeze Posted July 24, 2007 Share Posted July 24, 2007 My 04 JDM LGT wagon has a problem. When you turn the front wheels going forward or backward (much more noticeable in reverse) it skips and jumps like it has a locked front diff (for anyone that has own a fwd with a plate lsd or welded diff). Going forward it is very understeery. Anyone every had this problem or know the cause? Link to comment Share on other sites More sharing options...
Breeze Posted July 24, 2007 Author Share Posted July 24, 2007 Oh yeah in effort to remedy I have fitted new lca bushes and just had a full wheel alignment, it is actually now worse than before. Link to comment Share on other sites More sharing options...
TravisS Posted July 24, 2007 Share Posted July 24, 2007 This is a shot in the dark... but possibly a horribly worn CV joint? Link to comment Share on other sites More sharing options...
whitetiger Posted July 24, 2007 Share Posted July 24, 2007 ^+1 Link to comment Share on other sites More sharing options...
specbFTW Posted July 24, 2007 Share Posted July 24, 2007 ^+2 Link to comment Share on other sites More sharing options...
Breeze Posted July 24, 2007 Author Share Posted July 24, 2007 She hasn't many miles on it but it has had been in an accident that broke the lhs alloy lower control arm and bent the lh arm of the steering rack (both are brand new). I was thinking this may be the problem and have jacked it up and spun the wheels with no problems at full lock in either direction. Oh yeah I also had to replace the lhs front wheel bearing because it was noisy. Link to comment Share on other sites More sharing options...
whitetiger Posted July 24, 2007 Share Posted July 24, 2007 ^but there was no load on the drivetrain with the wheels off the ground. Link to comment Share on other sites More sharing options...
