Stang70Fastback Posted March 29, 2010 Share Posted March 29, 2010 I will be stealing your Spec.B. Just FYI. That is all. Link to comment Share on other sites More sharing options...
30legacyl Posted September 2, 2010 Share Posted September 2, 2010 Bump for update please! Link to comment Share on other sites More sharing options...
Aczwild Posted September 4, 2010 Author Share Posted September 4, 2010 You dont want this update. In assessing the rules/regs of SCCV, COM, NER and Hillclimb I have decided that the chassis would no be safe enough to run the car flatout in high stress environments. So the performance side of the rebuild is out of the question, so I'm going to swap the running gear from the rusted out wagon into the sedan shell as a DD. Although with that sad news, I went out and bought something much better to work with for racing, a '98 Impreza RS that has already been getting a lot of attention. Pics and the mod list to date (with stuff I have waiting to go on when I get the rest of the components) follows http://i7.photobucket.com/albums/y272/Aczwild/DSC03055.jpg http://i7.photobucket.com/albums/y272/Aczwild/DSC03068.jpg Modifications: (RED items are in my possession and will be installed when the rest of the supporting components are in hand) Engine/Transmission Group N Engine MountsACT HD ClutchACT HD Pressure PlateKartboy Short Throw ShifterKartboy Front Shifter BushingsKartboy Rear Shifter Bushing Interior JDM STi Stainless Steel SillsCorbeau FX1 Regular Fixed Back Racing Seat (Drivers Side)Corbeau GC8 Seat Bracket'07 Spec-B Female Seatbelt Receptacle (to clear racing seats)White HVAC LED ConversionWhite LED Gauge Cluster ConversionWhite LED Window Switch ConversionLED Map LightsLED Dome Light ArrayRemote Unlock AddedCruise Control AddedPassenger side Oh-**** Handle AddedTrunk Light Added & converted to LEDSony Xplod CDX-F5700 Reciever (came with the car, will be replaced)Defi (or a knockoff) CF 60mm Center Gauge PodDefi (or a knockoff) Plastic dash look 60mm Center Gauge PodSparco 6pt Harnesses (2x), will be converting to 5-pt Exterior LED Plate LightsJDM "Clear" Tail Lights (Brand new)JDM Clear Parking Lights (Brand new)Grimmspeed Antenna DeleteGrimmspeed Window Antenna KitThule Roof RackThule Kayak RacksThule Paddle CarriersThule 611 Boxter Suspension/Handling/Braking Group N Top HatsKYB AGX Struts (front only)Goodridge Stainless Steel BrakelinesBrembo RotorsStoptech Front 4piston Calipers (Black) Stoptech 2-piece Floating 328x28mm Slotted AeroRotor (Front) Stoptech Front Stainless Brake Lines Axxis Ultimate Front Brake PadsMotul RBF 600 Brake FluidRear Stainless Steel Stoptech Brake Lines Brembo Rear CalipersSTi Brake Booster & Master Cylinder JDM'd All to hell Thanks Jimmy @ Hkc-Speed.com! RIP Coxx & Thanks Link to comment Share on other sites More sharing options...
THE RZA Posted September 27, 2010 Share Posted September 27, 2010 are you still intending on swapping the ej22 in to that or doing a differant engine build? Link to comment Share on other sites More sharing options...
