REM87O Posted May 20, 2007 Share Posted May 20, 2007 I did it tonight and have a suggestion. I used a 17mm box end wrench to get the banjo bolt started. I then switched to a shorty to get it the rest of the way. The screen was dirty but not blocked. Also, for those of you with BMW's (e36 at least), the oil drain plug copper washer is the same size. Luckily, I have plenty on hand since every filter comes with one and I have been using the fumoto valve. Thanks to Rao again for the write up. Link to comment Share on other sites More sharing options...
Guest Posted May 20, 2007 Share Posted May 20, 2007 The screen was dirty but not blocked. Ticking bomb then. How dirty? How many miles? Link to comment Share on other sites More sharing options...
REM87O Posted May 20, 2007 Share Posted May 20, 2007 Ticking bomb then. How dirty? How many miles? 60K, synthetic oil since 12K. I pulled the screen out of the bolt and dried it with a towel and let it sit on some paper towel. When I held it up to the light, you could tell it was dirty, not just oily. Hit it with some wd-40 (and a little PB cause I like the smell) and wiped it down held it to light again and it was blotchy dirty so I hit it again. I also took a small dental pick and used some paper towel to clean out the inside. When I was done it was visibly clean when I held to the light. I thought about leaving it out but figured I would replace it for now. Passenger side is next. Link to comment Share on other sites More sharing options...
rao Posted May 20, 2007 Author Share Posted May 20, 2007 (and a little PB cause I like the smell) Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
mccorry Posted May 20, 2007 Share Posted May 20, 2007 The banjo bolt system is the same as you would find on a brake line at a caliper. You can reuse the copper seal washers without any issues. Link to comment Share on other sites More sharing options...
SeeeeeYa Posted May 20, 2007 Share Posted May 20, 2007 There is just something wrong here. Subaru has known for YEARS these filters could cause problems in the AVCS, which range from small driveability issues to larger ones when the filters actually fell into the AVCS system, and smartly removed them via TSB for that. But then to put them into our turbo motors with the potential for not only blown turbos but the resultant catastrophic engine failures as well .......... !!?? AND NEVER A MENTION TO ANYONE NOR CONNECT THE DOTS, DESPITE BLOWN TURBOS AND BLOWN MOTORS..... WTF is wrong with this picture. Some of my faith in Subaru is not as blind as it was. Link to comment Share on other sites More sharing options...
j255c Posted May 20, 2007 Share Posted May 20, 2007 i will be removing my filters this summer. Just doesn't seem like its worth keeping them in the long run. 06 TB EVO IX SE stock turbo monster subaru hater Link to comment Share on other sites More sharing options...
PhilT Posted May 20, 2007 Share Posted May 20, 2007 The banjo bolt system is the same as you would find on a brake line at a caliper. You can reuse the copper seal washers without any issues. Just remember to anneal them Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
KGreb Posted May 20, 2007 Share Posted May 20, 2007 Removed my turbo side filter today. Zero debris at 25k miles. Synthetic oil changes every 5k miles. Link to comment Share on other sites More sharing options...
rao Posted May 20, 2007 Author Share Posted May 20, 2007 Just remember to anneal them I'd just replace the whole motor Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
TSiWRX Posted May 20, 2007 Share Posted May 20, 2007 ...(and a little PB cause I like the smell) ..... :lol: From a fellow Ohioan, that's pure . <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
PhilT Posted May 20, 2007 Share Posted May 20, 2007 I'd just replace the whole motor I thought you already had, well apart from the copper washers which you reused Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
rao Posted May 20, 2007 Author Share Posted May 20, 2007 I do the motor every week, the transmission twice a month. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
LittleBlueGT Posted May 20, 2007 Share Posted May 20, 2007 I do the motor every week, I wonder how many more time I see that written by you? Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
fweasel Posted May 20, 2007 Share Posted May 20, 2007 I wonder how many more time I see that written by you? Is that Canadian for something? ignore him, he'll go away. Link to comment Share on other sites More sharing options...
rao Posted May 20, 2007 Author Share Posted May 20, 2007 I wonder how many more time I see that written by you? At least one more - I rebuild the engine every week and the transmission every 2 weeks. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
LittleBlueGT Posted May 20, 2007 Share Posted May 20, 2007 At least one more - I rebuild the engine every week and the transmission every 2 weeks. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
rao Posted May 21, 2007 Author Share Posted May 21, 2007 Did I mention that I replace the clutch every week too? Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
praedet Posted May 21, 2007 Share Posted May 21, 2007 I just buy a new car every 2-3 days and transfer the mods Link to comment Share on other sites More sharing options...
LittleBlueGT Posted May 21, 2007 Share Posted May 21, 2007 Did I mention that I replace the clutch every week too? Much easier when you already have the motor out. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
2005garnetGT Posted May 21, 2007 Share Posted May 21, 2007 Much easier when you already have the motor out. he hottanks the bare block as well.. its the only way to actually keep his turbo's CHRA alive. even then, he swaps turbos every month. Link to comment Share on other sites More sharing options...
rao Posted May 21, 2007 Author Share Posted May 21, 2007 Much easier when you already have the motor out. You know it. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
SeeeeeYa Posted May 21, 2007 Share Posted May 21, 2007 rao Not saying I don't enjoy the facetious banter but I suggest this information be formatted in a more serious context and made a sticky. The community NEEDS this. Link to comment Share on other sites More sharing options...
mccorry Posted May 21, 2007 Share Posted May 21, 2007 Meh..... So far... they've all been clean. I've yet to see a photo of a plugged (even partially) filter screen. All hype... not substance thus far. Link to comment Share on other sites More sharing options...
REM87O Posted May 21, 2007 Share Posted May 21, 2007 Meh..... So far... they've all been clean. I've yet to see a photo of a plugged (even partially) filter screen. All hype... not substance thus far. Ha ha! I got a picture for you right here buddy boy... I would love to see one from one of those blown turbos. Link to comment Share on other sites More sharing options...
