SLegacy99 Posted April 22, 2007 Share Posted April 22, 2007 So my passenger side turn signal sometimes blinks invariably...like an old Chrysler. Sometimes its fast, sometimes it slow, sometimes its normal. I replaced the bulbs, no good. Is it a relay? How do I fix it? Thoughts? Link to comment Share on other sites More sharing options...
pillboy Posted April 22, 2007 Share Posted April 22, 2007 I think the same flasher unit does the work for both the driver and passenger side, so that would point to an issue with the passenger side wiring, bulbs, & sockets. Are the contacts in the sockets clean? I use one of these to clean corrosion from bulb sockets...it is marketed for removing rust from paint chips before touching up the paint. It is still ugly. Link to comment Share on other sites More sharing options...
tekkitan Posted April 22, 2007 Share Posted April 22, 2007 mine does this sometimes too. i think it is only when it is kind of wet outside though. i haven't noticed it on mine in a while. Link to comment Share on other sites More sharing options...
SLegacy99 Posted April 23, 2007 Author Share Posted April 23, 2007 Will try that, thanks. Link to comment Share on other sites More sharing options...
SLegacy99 Posted April 26, 2007 Author Share Posted April 26, 2007 ITs getting worse. Link to comment Share on other sites More sharing options...
pillboy Posted April 27, 2007 Share Posted April 27, 2007 Would the contacts in the turn signal lever have anything to do with this? I have never had one apart. My '02 Outback service manual is no help - no troubleshooting guide. My Camry service manual lists the following possible causes for "abnormal turn signal function": bulb; turn signal switch; wiring harness. It is still ugly. Link to comment Share on other sites More sharing options...
BDII Posted April 27, 2007 Share Posted April 27, 2007 this is a sign that a bulb or a fuse is weak. A car ECU will flash a bulb at a different rate when it detects a malfunctioning peice. Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
SLegacy99 Posted April 27, 2007 Author Share Posted April 27, 2007 this is a sign that a bulb or a fuse is weak. A car ECU will flash a bulb at a different rate when it detects a malfunctioning peice. See thats what I thought, and people told me I was crazy. Thanks. Link to comment Share on other sites More sharing options...
pillboy Posted April 28, 2007 Share Posted April 28, 2007 I thought you said in your first post you replaced the bulbs??? It is still ugly. Link to comment Share on other sites More sharing options...
SLegacy99 Posted April 28, 2007 Author Share Posted April 28, 2007 I thought you said in your first post you replaced the bulbs??? I did. Not the fuses. Link to comment Share on other sites More sharing options...
SLegacy99 Posted May 15, 2007 Author Share Posted May 15, 2007 Still havent figured it out. It was blinking so fast yesterday and today it was normal. Im thinking it might be the front bulb but I dont feel like buying Amber bulbs if I dont have too. I did notice that if you remove the bulb it does the same blinking thing.......hmmm Link to comment Share on other sites More sharing options...
Kaos22B Posted May 16, 2007 Share Posted May 16, 2007 With the other things that you've checked, go look at the grounds, on your car there should be a couple, one on each front side under where 1) the battery sits (as in UNDER, like looking up from the ground) and 2) under the ABS pump Take them off, sand away any corrosion, reinstall, then spray over it with anti-rust paint. Goodluck. Kian Link to comment Share on other sites More sharing options...
BDII Posted May 16, 2007 Share Posted May 16, 2007 have you tried changing your blinker fluid? Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
Fox06LegacyGT Posted May 16, 2007 Share Posted May 16, 2007 have you tried changing your blinker fluid? :lol: Link to comment Share on other sites More sharing options...
SLegacy99 Posted May 16, 2007 Author Share Posted May 16, 2007 have you tried changing your blinker fluid? No, but I already replaced my headlight fluid...man that stuff is expensive! Link to comment Share on other sites More sharing options...
pillboy Posted May 17, 2007 Share Posted May 17, 2007 No, but I already replaced my headlight fluid...man that stuff is expensive! I hope you didn't forget the proprietary Subaru Blinker Fluid Conditioner. It is still ugly. Link to comment Share on other sites More sharing options...
SLegacy99 Posted May 17, 2007 Author Share Posted May 17, 2007 I hope you didn't forget the proprietary Subaru Blinker Fluid Conditioner. Uh-oh...it was Bosch! NOOOOOOOO. Link to comment Share on other sites More sharing options...
bblue2 Posted May 19, 2007 Share Posted May 19, 2007 try a turn signal flasher relay, it may be pulling it down to ground. you can test the grounds for both the relay and the sockets Link to comment Share on other sites More sharing options...
SLegacy99 Posted May 19, 2007 Author Share Posted May 19, 2007 I dont wanna jinx it, but ever since I pulled the whole thing out and put it back, its been fine. Maybe it was just loose. Link to comment Share on other sites More sharing options...
SLegacy99 Posted May 21, 2007 Author Share Posted May 21, 2007 Now that my turn signal is working again my left speakers decided that they would stop working. Loose wire of some sorts. I HATE THIS CAR. Everytime I fix something, a new problem arises. ITS A F*****G LEMON! LAME!!!!!!!!!!!!!!!!!!!!!!!!!!! Link to comment Share on other sites More sharing options...
MakoTako Posted August 13, 2009 Share Posted August 13, 2009 hey guys, I know that this thread is pretty old, but I'm having the same problems on my passengers side turn signal, and mine is also intermittent. Sometimes it blinks fast and sometimes its slow. You can also tell that there is less power to that side. And sometimes the front will blink, then the back will blink, like they are blinking seperately. Sorry but I don't have the service manual yet and I'm wondering where the turn signal flasher relay is? Thanks in advance for the help guys. Link to comment Share on other sites More sharing options...
Platinum_Racing Posted August 14, 2009 Share Posted August 14, 2009 This is a problem with a flasher. If no bulbs are burned out it is the flasher. The speed of the flash has NOTHING to do with the ECU, they are in no way, shape, or form wired or connected to each other at all. The ECU has no idea when a bulb is dying, or even when the blinker is on. The wiring harness for the blinkers are connected to an electronic flasher, NOT the ECU. The reason if flashes faster is because the flasher is designed to run with a certain amount of amperage draw. When a light burns out the amperage drawn off the flasher is reduced, this removing some load. The reduced load makes the flasher blink faster. If you were to wire an extra bulb to the flasher, it would flash slower due to the added amperage draw. An increased flash rate may be due to a burned out bulb, or a dying flasher. The flasher for the 99 LGT is an EF34 Electronic Flasher, cost... $9.99 at Autozone. Could also be a loose wire from the hazard switch. What happens when you turn on the hazards? http://www.autozone.com/autozone/catalog/parts/partsProduct.jsp?skuDescription=Blazer+/+Turn+Signal+Flasher&categoryDisplayName=Electrical+%26+Lighting&fromString=search&itemIdentifier=6416_0_0_&productId=6416&sortType=&parentId=57-0&filterByKeyWord=flasher&isSearchByPartNumber=false&navValue=15701559&categoryNValue=15799999&fromWhere=&itemId=1559-0&displayName=Turn+Signal+Flasher&store=5017&searchText=flasher&brandName=Blazer Link to comment Share on other sites More sharing options...
MakoTako Posted August 14, 2009 Share Posted August 14, 2009 So by flasher, are you meaning the Flasher Relay like what the other guys were saying or is this something different? I understand what you are saying about the amperage draw and I hope that this is just a simple fix. I wasn't able to check out the car last night but hopefully I get a chance tonight. I'll let you know what happens when I turn the hazards on. Thanks. Link to comment Share on other sites More sharing options...
Platinum_Racing Posted August 14, 2009 Share Posted August 14, 2009 More or less, yes. A flasher and a flasher relay are the same things. The link in my last post will take you to the Autozone website complete with a picture of the flasher. Link to comment Share on other sites More sharing options...
MakoTako Posted August 15, 2009 Share Posted August 15, 2009 Cool, thank you so much Platinum_Racing, Hopefully I can check it all out this weekend. Link to comment Share on other sites More sharing options...
